Question about Acer AL1716 F Monitor
When switch on computer monitor light goes from orange to flashing green and takes a long time to get a screen up
  • 63 Answers
SOURCE: monitor screen blank and LED orange light flashing
For some reason, it seems as if your monitor has either lost the video signal or the capability to interpret the siganl. If you have the ability, put a second monitor (or tv) to your computer. See if you get a video siganl. If you do, then your monitor has an internal issue with the signal and needs to be addressed "hands on" by a technician. If you do not see a video, then your problem lies within your video card. Good luck.
Posted on Aug 20, 2007
  • 4 Answers
SOURCE: monitor keeps going blank at start up
This looks to be a power supply fault - the inverters for the backlights are built into the power supply (Delta Electronics, model no. ADP-40AF).
Posted on Dec 11, 2007
gymowner
  • 679 Answers
SOURCE: Blank Screen & flashing button
It is one of three things, One is that it's not recieving a signal, mine flash when the computer is shut down, several monitors do this now. The second is that the either the video card is in need of service, or if you don't have a video card in your machine, it is either a connection that is intermittent, check the other end of the cable, or the monitor is in need of service, there is a circuit board that gives it a boost on start up. How old is the monitor and what brand? all the info is needed to go any further, thanks, if it is 5 years old more or less it is the monitor gone bad, more than likely
Posted on Apr 09, 2009
  • 1684 Answers
SOURCE: ACER Al1916W goes blank in 3 seconds. It shows
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
benwabnick
  • 2404 Answers
SOURCE: Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
Posted on May 01, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Plug in, press power, green light flickers once per second after a while goes to once per two seconds. then on screen comes up saying " no signal". then it goes ( according to the now orange light} to...
It sounds to me like your computer is not sending a signal to the monitor. If you switch monitors (borrow one if you don't have one) and the results are the same, I would look for the problem in your computer. Assuming you never see anything on the monitor when starting up the computer, the video card is suspect.
Of course, you need to check the cable connections and see if the video card (if an add-on card) is tight in the slot in the motherboard.
Mar 23, 2010 | Gateway FPD2275W LCD Monitor
Nothing on screen, gren and orange light flashing
You more like have bad capacitors in the power supply. Open it up and look for capacitors with bulging tops. http://en.wikipedia.org/wiki/Capacitor_plague
Common problems fro 2~3 years old monitors/ TV.
Jan 03, 2010 | Acer AL1916W 19" WideScreen LCD Monitor
Acer monitor AL1706 Power On problem
You are more likely to have bad capacitors problem in the power supply, inverter circuits. I would look for bad caps first. Look at some of the sample here: http://s807.photobucket.com/home/budm/allalbums
Jan 02, 2010 | Acer AL1706AB LCD Monitor
Monitor only stays on for 30 sec. & then goes off then if I remove the power cord & re-power it up it comes on for another 30 sec. then goes back off
Howdy folks. There are only 3 things that can go wrong with a screen. Since you both are experiencing the same symptoms, let's ask the same question: When the screen goes blank, is the power button still green or is it orange? A green light indicates a good power supply and a bad screen. An orange light indicates a bad power supply but a good screen. I used to take them apart and try to fix them but they just aren't worth the trouble because they are so inexpensive nowadays.
Either way, I'm the bearer of bad news. It looks like you'll both be getting new screens. Please don't hold it against me when you rate my solution! ;-)
Jan 04, 2009 | E-Machines eMachines Monitor E15T4
Monitor has a hard time starting up
replace the "keyboard board" and the "power inverter board" (both boards)....
Oct 09, 2008 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Acer AL1716 F Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
