Question about Dymo LabelWriter 310 Printer
After I install the software for my Dymo labelwriter it tells me to ad from the printer setup utility or printer center click ad but is not coming up
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
Windows 7 compatibility, do you support this?
Here is the link for the driver Dymo LabelWriter 310 Printer for windows 7. All you have to do is just download the software and install and plug your Dymo LabelWriter 310 Printer so that it will detect and installed to your system. Have a nice day!
Feb 26, 2011 | Dymo LabelWriter 310 Printer
Trying to use USB connection. Power good. Program install seems correct. When told to connect USB to computer, nothing happens (no recognition.) Have to cancel out of install. Have checked out supplied...
Following are three possible issues you can easily investigate and correct:
Upgrading DLS or Adding an Additional LabelWriter
A previous LabelWriter printer may still be installed with documents in the print queue. You must delete any documents in the print queue for all previously installed LabelWriter printers before proceeding with the installation.
1.Open the Printers folder. Based on Operating System and system configuration, the Printers folder can be accessed in one of the following ways:
Start > Settings > Printers
Start > Control Panel > Printers & Other Hardware > View installed printers or fax printers
Start > Control Panel > Printers & Faxes
2.Double-click on the LabelWriter printer, the print queue will open.
3.Delete any pending print jobs and close the print queue.
4.Reboot your computer and re-run the DLS installation.
Installing DLS and a LabelWriter for the First Time
Some antivirus or anti-spyware applications may prevent the installation of DLS and the LabelWriter printer. You may have to temporarily disable these applications in order to successfully complete the installation.
1.Restart your computer.
2.After restarting, temporarily disable any antivirus and anti-spyware applications.
3.Install DLS, connect the LabelWriter when prompted during the installation.
4.Once installation has completed, re-enable any antivirus or anti-spyware applications.
DYMO Label Software Fails to Install because Word or Outlook is Running
While installing the DYMO Label Software (DLS), prompted with a message that Word or Outlook is open. How can I resolve this?
1.Exit Word and Outlook.
2.Open Task Manager.
??¦To open Task Manager press Ctrl - Alt - Delete.
3.Click on the Processes tab in Task Manager.
4.Verify that WINWORD.EXE and OUTLOOK.EXE are not running processes. If present, select every instance of WINWORD.EXE and OUTLOOK.EXE and click on End Process.
5.Close Task Manager and reinstall DLS.
Should you require updated driver/software for your printer and operating sytem, check here.
Trust this helps resolve your installation problems. Please vote.
Dec 29, 2010 | Dymo LabelWriter 330 Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 400 laser turbo prints the label then multiple labels after that
This is due to the print template you have chosen.
control panel > printers > right click dymo print icon > properties > press "printing prefrences" in General tab > click "Advanced" button in layout tab
Here you can choose the paper size. The dymo "shipping label" (30573) sold in most office stores is template number is "30323 Shipping".
Also these templates choices are available in the software you are using to print the labels under file -> print setup or whatever your software calls it..maybe "print setup"
Hope this helps.
Jan 21, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
I don't speak French
Try Deleting the DYMO Label folder under C:\Programs Files, then install the DYMO Label program one more time.
Oct 29, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo 320 labelwriter downloadfor windows vista
Installing Dymo software on Vista can be a real nightmare if you fail installation at first time.
Call Dymo customer support, they will follow you step by step, ask you to download dymo uninstaller for your model, and tell you how to clean registry. They got used to this.
DYMO | Contact Us
May 14, 2008 | Dymo LabelManager 300 Desktop Labelmaker...
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Dymo LabelWriter 310 Printer Logo
128 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
