Question about Gigabyte Computers & Internet
Hi i have bended pins on my mother board in CPU socket.the motheboard is Gigabyte ex58-ud5 with x58 chipset and LGA 1366 socket for intel core i7.pins are not broken just bended.do you know any way to repair the pins so that my motherboard would work or is there any way to replace cpu socket.thanks for your help
  • 601 Answers
The bented pins on the mother board can be repaired .For this disconnect all power cords, then use a tweezer to strighten the pins & no do not remove the pins .
Thanks
Smith.
Posted on Sep 06, 2009
I7 950 compatibility
The basic answer is no because the motherboard only accepts the socket LGA 2011 while the Intel i7-950 is a LGA 1366 socket.
Oct 15, 2013 | Gigabyte GA-X58A-UD3R Motherboard and...
Whistle sound
check your fans and all moving parts.tighten up your cabels.
May 19, 2013 | ASUS Sabertooth X58 LGA 1366 Intel X58...
How to recognise a pin and pi nnless processor
A pin Processor has metal pins on the bottom of it.
For an example let's use an Intel Pentium 4 processor, that fit in a Socket 478 processor socket.
http://www.cpu-world.com/CPUs/Pentium_4/TYPE-Desktop%20Pentium%204%20Willamette.html
Viewing the link above, observe the green square under the grayish metallic looking square.
The green square is a circuit board.
(Width and length, about the length of your first digit on your thumb)
The grayish metallic square, is a metal shell cover over a Chipset.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The Integrated Circuit here is the Processor.
The Processor is connected to the green circuit board. (PCB. Printed Circuit Board)
On the bottom of the green circuit board are contact pins. In this case 478 of them. (478 pins)
http://www.cpu-world.com/CPUs/Pentium_4/Intel-Pentium%204%201.7%20GHz%20-%20RK80531PC029G0K%20%28BX80531NK170G%29.html
The tiny metal contact pins fit down into matching socket holes, in the processor socket.
A Socket 478 processor socket,
http://en.wikipedia.org/wiki/Socket_478
(You can click on the photo to the upper right to enlarge it.
The next design to come out, has the Processor with contact pads, (Pinless), and the processor socket has the contact pins.
An LGA 775 processor socket,
http://en.wikipedia.org/wiki/LGA_775
Example of a Pentium Dual Core's bottom side. (LGA 775 processor socket is used),
http://www.cpu-world.com/CPUs/Pentium_Dual-Core/Intel-Pentium%20Dual-Core%20E2220%20HH80557PG0561M%20%28BX80557E2220%20-%20BXC80557E2220%29.html
There you have it.
A 'Pin' processor has metal contact pins on the bottom.
A 'Pinless' processor has metal contact pads.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 03, 2011 | Intel Computers & Internet
Sabertooth X58 mother board. New build. I am getting one long beep at boot and noting happens. All the fans and lights on the other board are working. Nothing on the Asus web site addresses one long...
Assuming all your supply voltages are OK and your memory is OK it has to be either the motherboard or processor that is faulty. There is no way of knowing which without substitution.
Take out the memory and remove any boards to be sure and check the supply volts with a meter?
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | ASUS Sabertooth X58 LGA 1366 Intel X58...
Which is the best cpu that can i buy? i have the gigabyte 8ipe775-g rev 1.1 thanks
Well that is kind of a far off question. Do you want to know the best processor on the market or the best processor for your motherboard?
The best one I would say for your motherboard (LGA775) would be Intel Core 2 Quad or Intel Core 2 Extreme (The extreme is just an unlocked and overclocked Core 2 Quad)
The best Processor on the market however would be on the LGA 1366 and LGA 1155 Sockets as teh Intel Core I7.
Feb 03, 2011 | Gigabyte 8IPE775G (GA-8IPE775 G)...
Mother board 533 prescoot how the accpet ram and processer
This motherboard supports DDR2-800/667/533 Memory and any socket LGA775 CPU such as Intel Core 2 Quad, Core 2 Extreme, Core 2 Duo, Pentium XE, Pentium D, Pentium 4, and Celeron LGA-775 CPUs
Feb 01, 2011 | Asrock Pentium 4 (LGA 775-pin) -...
Asus 1366 X58 - Lights up on power. No diagnostic
The symptoms are problem at the CPU. Extract i7, check it vissually and try again. Try with one stick of memory too.
Stelios.
Feb 22, 2010 | ASUS P6TD DELUXE Motherboard LGA 1366...
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
What is compatible of video card of the motherbord pspe-vm
this is not a very great mother board. i suggest selling it on ebay or returning to manufactuar or store for refund and to buy a new mother board suggesting ASUS P6T SE LGA 1366 Intel X58 ATX Intel Motherboardhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813131386
Aug 07, 2009 | ASUS P5PE-VM Motherboard
Open Questions:
Computers & Internet Logo
48 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
