Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon mp180 not printing greyscale and color images, only sephia color. but can print black using scan and copy. what is the problem?
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
CANON mp 830 NOT PRINTING BLACK EVEN THOUGH BOTH BLACK INK CARTRIDGE IS HALF FULL. i have taken the print head out, cleaned the contacts and still the same. what else can I do?
Copy machine makers are notorius for forcing users to use a bit of the more expensive color mixed in with black. I can't print in black, it is called greyscale, therefore it has color in it. If you only print in greyscale, you'll notice your color cartridges going lower over time.
Mar 01, 2013 | Canon PIXMA MP830 All-In-One InkJet...
Attemping to copy a black and white image and either very small color or black lines appear over the image all over the copy I want printed.
In the advanced print options select the option to print in high quality greyscale. This method will solve the problem
Nov 30, 2010 | Dell 962 Photo All-In-One InkJet Printer
While printing in grayscale mode it is using color cartridges. It should use onli main black 520.
Open the printer "print options" or "Print Settings" and select the "Black ink only". I am not very sure about your model, but when you carefully check, you'll see "print in color" "Print in greyscale" it should be somewhere below the "print in greyscale". Hope this helps. Good luck. Thanks for using FixYa.
May 30, 2010 | Canon PIXMA MP830 All-In-One InkJet...
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
The ''odometer'' shows greyscale as colour
Any machine I'm familiar with has a default colour setting that you can set to either colour or black & White. Check in your printer properties. If the machine is set for colour, even if you are printing all black text for example, it will "make" the black from the colours, thus registering it as a colour document.
Jun 22, 2009 | Canon Office Equipment & Supplies
Problems with greyscale printing as colour on the Canon CLC3220
From whatever software you are printing, you will need to select the properties or features. In Pagemaker, it was features, but most other programs I now see it under properties for the 3220 on the print screen. You will need to find where it gives you the options for color. They should be color, greyscale or black & white. The default is generally color. Generally the 3220 will know if it is not a color document and print the black and white as a greyscale, but sometimes you have to force it.
If you are printing crop marks and color bars, then your document is recognized as color even though it may not be.
Finally, some programs use a black that is actuall 100% of CMY & K. If you are using InDesign and select registration as your black, instead of the plain black, then you document is recognized as color.
The same holds true if you select a pantone grey which is created from several colors. So also make sure that your document is truly greyscale and or that you tell the copier to print in greyscale.
Jun 16, 2009 | Canon Office Equipment & Supplies
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
5 PGBK vs. 8BK ink cartridges
No there is no way you can adjust it just to use the small black. When copying greyscale or printing greyscale it will use the big black, When printing colour it will always use the small black so there is no way around it!
sorry, hope this helps
Oct 14, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Canon PIXMA iP4200 InkJet Photo Printer Logo
123 people viewed this question
old marine
old marine
