Question about Kenmore 73932 Gas Dryer
Kenmore Dryer won't stay running
It's a 73932 dryer. When the dryer will only run with the door closed and the start button held in. If you let go of the button, the dryer stops. Any ideas where to check? I'm pretty comfortable replacing parts, checking volt/ohm measurements if I know where to look.
  • Anonymous Dec 11, 2007
    My Kenmore Elite model 110.63932101 wont stay running unless you hold down the start button. As soon as you let go it shuts off.
My ge dryer did this.. turned out to be switch which shuts dryer off if belt breaks had gone bad..hope this helps as repairman replaced motor first before finding
Posted on Aug 14, 2010
If the thermal fuse is bad the dryer won't run at all, or it will have stopped heating completely. more likely this is a unit with a power control board in the console. these were very known for the resistor on the board burning out which can be checked visually. i've had at least 6 or 7 of these do that exact same thing. hope this helps.
Posted on Dec 29, 2007
  • 146 Answers
You need a new thermal fuse. The fuse is located on the blower wheel cover. This fuse cannot be re-set. Replace if open (there is no continuity between terminals). Part number is AP3132867. It is a Whirlpool part but it is the one that fits most if not all Kenmore/Whirlpool dryers.
Posted on Dec 21, 2007
4 Suggested Answers
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Posted on Nov 25, 2007
  • 1028 Answers
SOURCE: Start Button will start dryer but won't stay on!
pull end caps off just grab at top of plastic and pull towards you remove the 2 screws underneath lift console up and roll back next to timer is a small control bd to right of that are 2 relays 1 with red wires for element and 1 with blue wires for motor first try switching the relays they are identical and will work for either 1 ..try if works replace relay ..if still not working suspect control bd
Posted on Jul 01, 2008
  • 958 Answers
SOURCE: Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
Posted on Sep 14, 2008
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
Kenmore dryer mod @ 110.67422600 won't start
Plan on changing this start-button.
Sep 15, 2012 | Kenmore Dryers
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
My kenmore dryer will only run if i hold down on the start button. this has happened to me before but i cannot remember the steps to take inorder for it to reset.
first check the door safety switch,, if its bad the dryer won't run,, if that checks out ok, its time for a new switch for the start button, to check these, and do the door switch first, unplug the door safety switch and place a jumper wire between the 2 wires leading to the switch, try starting the machine making sure your away from any moving parts , if this works, replace the switch, if it stays the same, do this same procedure to the switch for the start button
Jun 21, 2011 | Kenmore Dryers
I have a Kenmore 500 series dryer. The dryer just stopped working but the light stays on when the door is closed.
the door switch is broke.when you push on the paddle of the door switch the lite should go out,if you don't see the paddle it most likely broke off,you need to send the full model number next time,it will start with 110.or similar.the door switch is a safety so the machine won't run until the door is closed,if the switch is broke no power will go to start the dryer
May 10, 2011 | Kenmore 500 6953 Dryer
The light does not go on and the dryer will not run?
If your sure you have power to the machine, and the light does not come on when you open the door, then you need to replace the door switch on the dryer.
Dec 21, 2010 | Kenmore 73932 Gas Dryer
Dryer won't turn on
touch the door swich and see if it clicks when you push in on it,if that is good you'll have to check thermal fuse that is located either on blower wheel housing or in back of dryer,check to see if belt broke some dryers have switch that kills dryer if belt breaks
Nov 03, 2009 | Kenmore 73932 Gas Dryer
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore gas dryer timer? problem
Sounds like your centrifugal switch on your drive motor may be defective. The switch is supposed to "latch" (or stay closed) when the drive motor begins to spin. That...or, you may have a defective start switch. Please post back with your COMPLETE model number so I can determine how your dryer is configured as all dryers are not alike. I need to make sure.
Oct 26, 2008 | Kenmore 73932 Gas Dryer
tnx 4 using fixya,
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73932 Gas Dryer Logo
1,785 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
