Question about Microwave Ovens
Hello, I have a GE over oven microwave model JVM1650WB008 and it suddenly stopped working after heating up a bowl of spaghetti. i have tried unplugging and other things with no luck. It is completely dead. I was hoping to try to check the fuse and I followed your links to find a parts explosion but unfortunately I cant seem to figure exactly where the fuse would be. Could you help guide me a little further to try and locate it? I would very much appreciate it.
  • 1,031 Answers
Check if there are screws on the side of the control panel (along top too) the panel then slide up on clips and pull towards you
Posted on Sep 06, 2009
  • Starnley Johnwells
    Starnley Johnwells Sep 06, 2009
    If the control panel is not removable then the entire cabinet has to come off.
    Removing the control panel - most likely you will have to remove the louvers or trim above the cooking cavity to get to the fuse, look for screws holding the trim/louvers on, if no screws are apparent, the piece may slide to the left or right and pop off.
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
GE Spacemaker Microwave #JVM1650WB008 is not heating.
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1650WB008 Microwave. Daughter used left
probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE turn table microwave stopped warming food
my microwave 1640GB from GE suddenly cannot heat food and make some noisy sound. as it is mounting in the closet, it is not easy to replace. any solutions or suggestion
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I believe the inline fuse is blown - where is it
my microwave will not heat food turn table is not moving and showning red smybols
Jan 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Sep 06, 2007 | GE JVM1660 Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
