Question about Microsoft Xbox 360 Console
Third ring turned red it shows E 74
Third ring turned red it shows E 74 . right before I shut it off I noticed
the picture was dotted I turned it off and when I restarted it back up
it showed red ring was there . It showed E 74 and web site.
  • 20 Answers
:( Feel Sorry for you. 3/4 of RROD means a SUPERFRIED Xbox. give it to a hobo and say Merry Fakemas!
Posted on Sep 07, 2009
My xbox 360 has 3 red lights and is not working
Turn your Xbox off for like 3 hours..... Turn it back on, if ERROR 74 shows up then you have RROD "Red Ring Of Death".... https://myservice.xbox.com/en-us/Pages/Welcome.aspx If you haven't had it for three years yet, you can send it in to Microsoft and they will fix it free of charge... Next time, try to use the Xbox less.... The more you use it the more it is prone to overheating melting a motherboard chip thus causing error 74
Jan 08, 2011 | Microsoft Xbox 360 Console
When i turn on my xbox I get a the "red ring of
order the red ring of death self repair kit,,very simple,,also try blowing xbox out with a aircompresser,,worked for mine,,and geta hex head screww driver tighten screws on the botom of xbox 360,,,may hlp...
Nov 03, 2010 | Microsoft Xbox 360 Console
I have 1 red ring and it said to come hear it said E 74
Yes this is the display chip overheating you will need to fix this to do this send it in or use a good guide to fix it from home.
Jul 13, 2010 | Microsoft Xbox 360 Console
My xbox has E74 what do i do about getting it fixed, however it only shows one red ring in the bottom right of the circle when it is turned on, not three
The Error 74 means that your 360 is experiencing hardware failure. Only one red light should show up. You should send you 360 to Microsoft for a repair. If you are not under warranty you could fix it yourself, by doing the X clamp repair. But by opening your 360 it will void your warranty so be careful.
Hope this helps
May 07, 2010 | Microsoft Xbox Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
Error 74 red flashing light in third spot, x box shut down
First thing you do is check all cables!! if that doesnt help: the good news is that the 1 red light and error E 74 show the same fault, the bad news is that you need to contact support as it looks like a hardware faliure which is normal for the xbox (here is the link to the MS troubleshoot page)
http://support.microsoft.com/kb/941377?sd=xbox
This is not the classic "red ring of death" so im not sure where you are going to stand with the 3 year warranty
Jun 29, 2009 | Video Game Consoles & Games
ERROR 74 on xbox 360
It's a AV cable error. Try the switch on your cable. Move the switch while the console is on then turn it off and back on again. If this doesn't work then do the xclamp fix. This fix is not just for the 3 red rings.
Jun 04, 2009 | Microsoft Xbox 360 Console
Self- reboots at start-up, then shows picture but with pink dots.
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM811, CM812, CM817 & CS806; 1000ufd 25volts. It is the board to the left and you notice that the four cap tops are swollen.
It is easy to replace get a stanard solder pencil and you are in business.
Thanks for using FIXA, BIG IRISH.
May 24, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Sharp TV model 27H-S60 convergence
HI ,USE A PATTERN GENERATAR DOT OR LINES TYPE AND USE THE CONVERGANCE RINGS BEHIND THE YOKE OF THE SET ,THERE ARE THERE RINGS FOR EACH COLOUR RED GREEN AND RED .SLIGHTLY MOVE THE RINGS AND U CAN SE EIN THE PATTREN THE COCLOUS WHICH IS FRINGES EACH BY EACH U ADJUST ALL THERE RINGS FOR PERFECTION , FIRST LET THE SET BE SWITCHED ON FOR 1 HOUR AND THEN DO THE ADJUSTMENT. THANSKS
May 22, 2008 | Sharp 27H-S60 TV
Microsoft Xbox 360 Console Logo
154 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
