Question about Emerson EWL3706 37 in. LCD Television
It has a small red line towards the middle & a small blue line at the right side of the screen. They run from top to bottom. The blue line appeared first. Most of the time once the t v is on for several hours the red line will go away & the blue line does also but not as offten as the red line. I have an Emerson LCD HDTV Model# LC320EM9
  • sassie130 Sep 06, 2009
    That didn't help at all.
    President:
  • 1,197 Answers
Hi
Have you tried using a new video cables? Alot of times when a composite cable(or others) get cracked, or a loose connection this is an issue.
if not then its likely you have a problem known as vertical banding......
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
if your tv is not under warranty... and if you are comfortable repairing the tv urself..... go ahead with the below repair....
please make sure that you have unplugged everything before venturing for the repair..... as these units have pretty high voltages.... also when ur opening the unit make sure u do not accidentally disconnect the solders.... that would cause further complications.... o proceed with the below steps only if ur 100% comfortable....
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use rubber
Place the rubber on the top of TCP
It has a small red - 537523a.jpghttp://i.fixya.net/uploads/images/537523a.jpg" alt="537523a.jpg" class="h_mi" />
Gently close back the top It has a small red - 0f42523.jpg>
if that doesnt help....... it is advicable to get a tech help......
regards iversh
Posted on Sep 06, 2009
    Brigadier General:
  • 3,614 Answers
Try altering your display resolution in all its variables.
try altering RGB settings, contrast and appearance settings. If this does not work, most likely a hardware screen failure.
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Vizio display issues
Red and Blue seperate and picture curved toward the middle
You have a hardware problem, you cannot fix it using the menu. in fact you could make it worse.
Try googling DIY convergence repair if you can solder.
If not then call in a pro, about $300
Jul 12, 2009 | Toshiba 50H81 50" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Vertical line on side of LCD TV
Modern televisions have screens divided into sections. Each section controls all the rows in its area, and it is controlled by its own video separate video driver. If you are missing a line in a section, then a problem has occurred with the driver board in that area. It will be pretty expensive to fix, I hope your warranty has not just expired!
Jan 08, 2009 | Televison & Video
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Picture then fades to blue.
Please post me on this as well. My Sony just turned 4 yrs this Jan and just last week it started having the same problem. -Thanks!
Mar 02, 2007 | Sony KP-65WS500 65" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Emerson EWL3706 37 in. LCD Television Logo
739 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
