Question about Audio Technica ATW-T52 Professional Microphone
I have 4 Audio Technica mics in a rack and all have only been used about 30 times. Now one of the mics has no 'bass end' or gain. I've changed the batteries (we always use new batteries every show). I know it's not the PA because the other mics sound fine through the same channel on the desk. I've checked all of the leads and they are OK as well. I don't know if the problem is with the mic, or the receiver. Any clues?
    Brigadier General:
  • 3,614 Answers
The problem could be either your mic or the reciever, if all of the mic that was connecting to the receiver was not functioning the problem could be on the receiver. but if only one unit(mic) has not working this can only be the mic or the transmitter with it..
Hope this helps
Posted on Sep 06, 2009
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Nov 10, 2014 | Audio Technica Audio-Technica ATW-T202...
I have several microphones, one's Audio Technica ATM61HE hypercardioid mic, and it has (low) volume issues. i brought it to audiophile before, they don't have the spare part on hand though, and the part's...
You might consider sending it in to Audio technica for repair. They're really customer oriented and alot of times they'll repair and or replace for just cost of shipping. Try contacting them directly.
Apr 30, 2011 | Audio Technica Audio-Technica ATM61HES...
I am getting a high pitch poping sound from my atm25 bass drum mic
If this is only when you hit the bass drum, it's picking up feedback from being too far inside the drum or pointed at the wrong part of the head. Use a mic stand and position the mic off to the side, but in front of the head, pointed at the midway point between the center and edge of the drum head. This should eliminate the problem. If the noise is still present, have someone qualified to work on microphones look at it to determine what the problem is.
Hope that helps!
Feb 13, 2011 | Audio Technica Audio-Technica ATM25...
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
Wireless noise
the unit I'm using is old and is on a 200mhz frequency and it uses Vhf, so I have to buy a new unit.....nothing can be done to fix the problem....
Jan 21, 2009 | Audio Technica Audio-Technica 200 Series...
Loss of bass frequencies in dynamic mics
That's one correct assumption, but it's actually the element that gets damages causing the coil to rub. Open the top up and see if there is any damage, sung a magnifying glass as the tiniest crack could go un-noticed by the naked eye.
In testing these 2 did you change the frequency at all? trying with a different receiver, having another mic on the "bad" mics frequency?
Loss of lows can also be a sign of a bad wire as this sometimes tend to act as a high pass filter.
Did you do the obvious, change batteries?
jeff
Dec 22, 2007 | AKG D8000S Professional Microphone
Problem with MixerInputs
I have pretty much the same setup, as in snare and bass into the xlrs. You can change the physical jumper positions on the sound card, to give you a lower gain, as in mic/line (details in the manual) This lowers the input gain. Unfortunately, this can sometimes be too low. It's one or the other.
Sep 18, 2007 | M-Audio Delta 1010LT Sound Sound Card
Audio technica at 4040 constant ground hum noise
you can test the cable from connection to connection for continuity from end to end. There should be no resistance( a complete short) If the cable is good, there is a bad or broken connection inside the mic. Good Luck
Jun 23, 2007 | Audio Technica Audio-Technica AT4040...
Audio Technica ATW-T52 Professional Microphone Logo
50 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
