Question about Refrigerators
Drain in back of frigde keeps freezing up but not blocked
  • 32 Answers
This is a common problem. it can be rectified by replacing the drain pipe. it can be accessed from the back behind the condensor. you will have to cut open at the back to do the repair and once replced, reinsulate the insulation by using liquid foam obtainable from your local hardware.
Posted on Sep 07, 2009
Subz 550 drain tube keeps freezing up, causing water to spill onto base of fridge and freezing
i know this is late but there's a heater kit made for this 4202160 is part number,you remove the shelves,you can put a mark under the shelf arm on the far outside where the shelves hook on so you can put them back in the same spot,then remove the light cover,the two screws and metal cover and then pull the wall off and set it to the side ,the drain heater kit plugs into the wire harness,the heater will heat up and keep drain from freezing,you can slide the tube off,stick a screw driver in to hold it down to the floor so you don't burn your hand and blow hot air into it with hair dryer to melt out ice,keep heat on for like 20 to 30 seconds then cold air or remove heat you don't want to mess the hose up from overheating wait a bit and hit it again until you melt out the ice,then i use a long plastic wire tie to stick into drain hose to clean it out,some nasty stuff in there,i use a steamer to clean the line out and then i have a piece of 1/4 inch plastic water line to snake into the drain,if this is the first time this has happened you don't need the heater kit,just clean out the tube and metal drain trough,also clean the back of the top crisper drawer shelf,crumbs and stuff can get in between the back wall and the top shelf and then will fall into the drain,if you keep that area clean you won't have to many issues and keep the fridge a little warmer so it doesn't freeze up the water in the drain tube,put the drain tube back onto the trough and pour hot water into it,if it drains down you're done if it's still blocked get a turkey baster and push hot water down into the drain tube to clear it,if it still doesn't clear remove the bottom kick panel,you'll see the drain pan and look at it because you have to get it back the same way in the clips then you can see the drain tube,stick a plastic tie up in there to clean it,sometimes there could be dust or something in the drain pan,when the water hits it it can get into the bottom of tube and block it but i've only had to do that once,hope this helps you out.
Nov 16, 2017 | Sub-Zero Bottom Freezer Refrigerator
Why does my hotpoint refrigerator constantly drips water from the freezer bottom compartment?
you have a frozen defrost drain. you can thaw it with a hair dryer. it is behind back panel. turn off frigde remove back panel. Heat the drain with hairdryer under the coil. do this till water goes down drain Ihope this helps.
Aug 21, 2011 | Hotpoint Refrigerators
Hello i have an lg refrigerator GR-620RW which
LG 620 RW water in fridge below crisper problem.
The issue is most likely a blocked condensate drain line at the back of the freezer. The purpose of the drain line is to take away the water from the end of the defrost cycle.
Task time, approx 2 hours.
Unplug fridge.
Empty out the fridge, let warm up & remove the back panel of the freezer. There is a 3" x 4" snap in door at the upper left corner of the back panel with a round snap in cover. Remove the snap in cover & remove the screw to take out the 3" X 4" panel, gently pull out the back panel from left to right. There is also an elect connector to the fan on the upper right corner, unclip this. The drain is at the back in the centre, it will likley be blocked with 2 or 3" of ice. You can let it melt or sparingly use a hair dryer on it, do not over heat or damage the coil/fin assembly. The fridge will continue to drip water for a day after the drain is cleared if the water has rin inside of it for any period of time.
There is also a fan/control assembly in the refrigerator section held up by 2 screws & snaps. This should be dropped down to ensure there is not ice buildup in the vents to the freezer or water inside it.
Finally, make sure you run warm water down the freezer drain tube to the pan underneath the fridge, this is accessible by taking of the rear compresser cover behine the frigde. Ensure the lower drain line is clear & back on the locater peg.
Of course if you want to do this the easy, & have the time, leave the fridge open, unplugged for 2-3 days & the ice will all melt.
Good Luck
Jun 12, 2010 | Refrigerators
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer drips water into frigde filling up ottom tray
Hello, If it is a top mount freezer then there is a drain that runs from the freezer to the drain pan that gets gummed up sometimes and if that happens then the water has no place to go but the fridge. Look all the way in the back of the fridge and you'll see a yellowish colored tube. You can just pop that out and take it to the sink and clean it out.. Hope this helps
Feb 18, 2009 | Kenmore 62232 / 62234 / 62239 Bottom...
Frigde freezer
Sound like door seal is not closing tightly allowing moisture to be drawn in and freeze the contents. Below is a link with Q&A and solutions. Try this link and get back with us to help you get this fixed. Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Feb 01, 2009 | Thetford N641
Refrigerator
This is the most common thing on this site for refers. Its the drain line that takes water from the freezer when it defrosts to the pan underneath the appliance. You need to locate the drain line and remove the obstruction, sometimes its frozen so a short thaw may be helpful. The way I do it is I find the drain hose at the bottom of the fridge where it drains into the pan. I then connect a hose to it and blow compressed Co2 into the line. When there is no back pressure, I know its clear.
Dec 27, 2007 | Kenmore 53642 / 53644 Side by Side...
Kenmore / GE side by side defrost drain keeps freezing up
Check under the base, the tube must be clear to the water tray, often there is a rubber flow restrictor, this either perishes or blockes, either way remove it, defrost over night and then turn back on, should then work ok within 24hrs. Regards Adbvisor
Aug 15, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
