Question about Compaq Evo N610C Notebook
Computer wont start up fully
I go to start my computer and the compaq logo appears on screen as normal then it goes to a black screen with a small white flashing line in the top left hand corner of the screen and then will not go any further
    President:
  • 2,600 Answers
Your boot menu for Windows is corrupt. Try to boot from the windows installation disc and make sure to key any key when told to boot off the disc. Once the windows files load, you will have a choice of what to do next. If you have XP, choose the repair option and you will be faced with a black DOS screen...after the blinking cursor type
FIXBOOT hit enter
Try to boot the computer without the disc in it. If it does not boot, then boot off disc again and this time type:
FIXMBR hit yes and enter
Try once again to boot without the disc.
Also try to boot into safe mode by tapping F8 when you see the Compaq name come up during starting. If you can get to the multiple boot up option screen, scroll to "Safe mode with networking" and choose that. If it boots then you can go to the start button > accessories > system tools > system restore > choose a restore point back a day or two and follow the prompts.
If you have Vista, boot off the disc and choose start up repair. If that doesn't work, boot again and choose restore computer to an earlier time. Again choose a restore point back a few days. Good luck ParrotHead PC Repair
Posted on Sep 06, 2009
Start up will not run
Try getting in to Safe mode: F8 before Windows starts to fully load.
Start your computer in safe mode Windows Help
May 20, 2015 | Gateway Ne56r34u 15.6inch Laptop Black
I got this computer off side of road and can't get windows to load it's try's then the screen goes black . here is what happens . I turn it on the screen comes up black it asks what I would like to do ?...
The first screen (start windows normally etc) appears because the computer ahs not shut down normally before. Since you choose to start windows (normally or last known...) and the Windows logo comes up with the loading bar, this means that the computer is starting to boot. Some hardware or software (windows) problem appears and the boot never ends. Possible reasons: motherboard failure or hard disk failure. A good idea is to re-install windows to check the results. Mention that in case of reinstalling the windows, during the procedure choose to reformat the hard disk so it will be checked for errors and reported.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 02, 2010 | Intel Motherboard
Wont boot up
try removing all cables connected to your tower, (including power cable, mouse, keyboard, VGA cable, scanner, printer, camera etc.)- then press the power button for at least 5 seconds, this is what we call POWER DRAIN, then try booting up your system again, if still unresolved, power off your tower, then open up your chassis, reseat the cables of your HARD DISK -- try again. if still unsolved, try entering the BIOS, check if the HARD DISK is detected..
Sep 07, 2009 | Compaq Evo N610C Notebook
Windows xp will not load on my computer....
It could be your hard drive problem. Which I called it, "Crash." I would suggest you try to format the hard drive and reload the operation system with your installation CD.
Jul 22, 2009 | Acer Aspire™ T180 PC Desktop
Laptop won't start up
It sounds like your laptop is using it's external VGA adapter for its main display. Try holding down the Function (FN) on your keyboard located on the bottom left hand side and pressing F4 at the same time.
Jun 04, 2009 | Compaq Presario Notebook
Monitor displays Msg. frequency out of range, screen is black
Start your computer and press the F8 when the manufacturer's logo screen is showing. This will bring you to the Windows startup menu. Pick "start in VGA mode" and windows will start up with video settings you monitor can handle. Then you can change your video settings so Windows will start normally with your monitor.
Mar 31, 2009 | Compaq Computers & Internet
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Hi, I have a compaq deskpro that is working fine however, the monitor is having trouble. I took the monitor to the shop and it is fine also. Likewise, I placed a monitor from another computer onto the...
The monitor setting in windows maybe incorrect. When booting up before you get the windows logo start hitting F8 and then choose safe mode. If your monitor works in windows there then check the monitors settings. You may have a driver issue or a settings issue when in normal windows mode.
Jul 07, 2008 | Compaq Computers & Internet
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
Compaq Evo N610C Notebook Logo
321 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
