The water inlet does not stop during the entire cycle of washing in our NA F70GS Panasonic washing Machine. How to solve this problem?
  • Anonymous Mar 18, 2014
    Error u14
Its simple..just follow step by step as below:-
  1. Switch off and unconnected both power & water supply.
  2. Lay the unit with the back side facing up.
  3. remove the back & bottom panel
  4. you will see the valve on the bottom tub.
  5. Unscrew the valve cap.
  6. Dismantle the valve by release the connector between steel bracket & hook (white plastic 'T' shape) using small 'playar'
  7. Then you will see a 20 cents coin ( keep into your tabung gajah)
  8. Use the old toothbrush to clean the black rubber valve.
  9. Assemble everything.
  10. Thats all.
Posted on Jun 25, 2010
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
Panasonic NA-F80B2 doesn't filter Water to the machine
None ever have that I know of . the inlet hoses have a screen in to stop large chunks only
Jan 18, 2016 | Washing Machines
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Why does a kennmore washing machine work during the final spin and the water input does not stop?
does it only final spin? would say bad water inlet valve but should do the same in wash cycle also??
Mar 07, 2015 | Washing Machines
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Keeps filling during wash cycle
If the machine des not stop filling and cycle hang in position, then it is a faulty water level switch.
If the machine does not stop filling , and the cycle goes on, then test that the inlet valve is not stuck in open position, if the inlet valve is OK, replace the timer control assembly.
Mar 07, 2009 | Hotpoint Ultima WD72 Front Load...
Panasonic washing machine stops prior to spin cycle
First my washer stopped working during the spin cycle, and some of the water still in the tub,i have to wait for about half an hour to have the whole process done after continuing the washing process,then after 2 weeks not doing any laundry, when i tried to switch on the on/off button,it doesn't do anything at all!I tried changing the plug fuse(thinking maybe it needed to be changed after 4 years using it) but nothing happened.please help me . TQ
Mar 20, 2008 | Washing Machines
Washing Machines Logo
210 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
