Question about Samsung BlackJack Smartphone
0 characters
1 Points
Low volume for mp3 songs and ring tones
i am using sony ericsson wt13i whats my problem is i cant get ringtone volume while using songs as ringtone.pls give me solution how to solve this problem through my mail
Oct 30, 2012 | Sony Ericsson SonyEricsson WT13i battery...
Blackberry 8320 has absolutely no audio out. Can
Please follow the troulbe shooting steps given below.
press menu key, select profile, Under that select advance, press menu key, click on edit, select phone, you will get all the option, Click on ringtone, select Browser, under that select music you will list of songs, select anyone those songs for you're ringtone you will be able to hear the ringtone for you're selected songs.
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
How do I change the ringtone on my phone and for
Go to my stuff and into my sounds.
Oct 06, 2009 | LG KU990 Viewty
Hi i have the lg ku990 and cant change the ringtone can u hely th
you go into profiles> tap on the profile which you wish to change> tap on the tab in the bottom left hand corner> edit.
Jan 17, 2009 | LG KU990 Viewty
Problem using note file as ringtone
i went 2 at& & looked up phone & device support for the 8525 smartphone.
Dec 30, 2008 | Cingular Wireless Cingular 8525 Smartphone
How can I put bluetoothed ringtones as a Ringtone?
You have to put the music in my stuff through media player and when you go to setting then profiles click edit on the profile of your choice and where it says ring tone flick through and the ring tone should be there with all the others.
Jul 16, 2008 | Pantech Duo Smartphone
go to ur settings under ur start menu. after u open it open up the sounds then go to ringtone and go over until u c the ringtone u want
Jun 30, 2008 | Pantech Duo Smartphone
I-mate smartphone
you cant set regular songs (mp3) as ring tones. only ring tone files (m4a,wav) as ring tones. they are shortened versions. try Http://
for some good ring tones that are totally free
Jun 16, 2008 | i-mate Smartflip Smartphone
Cut or copy the songs from the folder you have saved it and then put it in the my Ringtones folder and same would come into ur drop down list for the ringtones.
Dec 12, 2007 | HTC Touch P3450 Smartphone
How can i add mp3 songs to my ring tones?
go into my stuff then choose storage card press select then choose my music and press select then select the artist that has the song you want as a ringtone, highlight that song and then press the menu key,tab down to "set as" option then press select, then highlight the ringtone and press ok . this will convert it to a ringtone for you.
Jul 16, 2007 | Samsung Blackjack SGH-I607 Smartphone
Samsung BlackJack Smartphone Logo
21 people viewed this question
Top Samsung PDAs Experts
Ronald Thompson
Charlotte Byrams
Charlotte Byrams
Are you a Samsung PDA Expert? Answer questions, earn points and help others
