Question about Canon PIXMA MP830 All-In-One InkJet Printer
I do clean head and i do test and no print cyan
SOURCE: Cyan, magenta and yellow not print after replace the new print head
I am going back to Epson
Posted on Jul 25, 2008
SOURCE: Canon IPF700 prints with stripes
I had the same problem. I realized that i was printing to the wrong paper type. It gives you several options, so make sure you are set to print on the right type or you will get banding. My issue was i was printing on Semi Gloss and my computer printer settings where on Plain. - Once i changed, it solved the problem.
Posted on Dec 21, 2008
  • 12 Answers
SOURCE: iP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Posted on Jan 21, 2009
SOURCE: MP830 Cyan Ink won't print
Soaking the print head in non-detergent ammonia works very well. It breaks up the dried ink clots perfectly. (Soaking in alcohol does not work nearly as well.) Be sure the head is completely dry before putting it back in the machine.
Arafin
Posted on Jul 18, 2010
duane_wong
  • 6826 Answers
SOURCE: My Cyan cartridge is producing streaky results -
Are you using genuine Cyan cartridge from Canon? or aftermarket?
Posted on Aug 03, 2010
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
I had fully-refilled the ink into the CISS tank of my printer (CANON IP1980) however, the only colors that went out were magenta and yellow only. no black or cyan. the ink from the CISS tank did flow into...
You could try a head cleaning or a deep cleaning. You can find them in your printer properties under maintenance. After a few cleanings, try a test page. Keep cleaning and trying a test page until it prints like it should. If it never prints black and/or cyan, the print head is either seriously plugged or damaged.
Aug 23, 2011 | Office Equipment & Supplies
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
May 24, 2010 | Brother DCP-120C All-In-One InkJet Printer
Not printing cyan tryed new cartridge
The print head is clogged.Try unclogging with cleaning tests in maintenance mode.If not help you can try unclogging manually.Warning!!!This can lead to damage of print head.Try it in last case.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left
it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.Call Canon for support.
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Clot Cyan head gave me a patch in self test i have
Check out this link to an HP-supported way of cleaning the print heads for that DJ.
Oct 20, 2009 | HP DesignJet 1050c plus InkJet Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
IP4300 only recognizes magenta OR cyan
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
