Question about Fuji FinePix A805 Digital Camera
I'm trying to take pictures in black and white. I
I'm trying to take pictures in black and white. I don't see the setting on the dial and I think I'm missing that page in the manual.
Page 90 of your user maual. Select function: b/w, sepia, or off (normal).
Posted on Oct 08, 2009
  • The Gordon Oct 08, 2009
    Sorry, wrong camera. :-[
    Still, search manual for menus and functions to find settings.
    Update:
    I downloaded the manual (pdf file) at:http://www.fujifilm.ca/documents/FUJI_A8...
    And did extensive searches but found no setting for B/W.
    Brigadier General:
  • 11,967 Answers
Go into the menu and see if you have an entry for "filters".
Posted on Sep 07, 2009
My camera is a Coolpix L830 and my pictures are usually yellowish....never with vivid colors..please help
I may be WHITE BALANCE. If it is SET to FLASH and you are inside it may look YELLOW. Go the the MENU and see what the WHITE BALANCE is SET to. If it is AUTO then you MAY have something wrong with the camera. I cannot say it is the camera yet.
Feb 15, 2015 | Nikon Coolpix L830 16.0 Megapixel Black...
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Hi there, I have a canon powershot sx130 and I don't know how to change the colour settings on it to black and white? If you could please give me the steps to do this it would be greatly appreciated!...
I have the SX10IS your options should be the same. You only have the option to change colors in the manual modes (on the dial; P, Tv, Av, M & C). Press 'func. set' button, on the menu on the left the second option down is a paintbrush that is the my colors menu, select it and you can scroll through to black and white. Also as an option most photo software can convert a color image to black and white.
Jul 30, 2011 | Canon PowerShot SX130 IS Digital Camera
Color poor, essentially black & white
Hi
Thanks for using FixYa. This issue is caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Please also check the convergence board for cracked solder. If you want to do the repair yourself there are repair kits available which includes instructions on how to replace them. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | Philips 50P8341 50" Rear Projection...
When I am in action mode (with the dial turned to the running man my picture is blurry and yellow
The mode you mention above is prioritized for speed moving object such as racing, basketball game, etc...
the blurry condition is caused by the movement was too fast so the camera couldn`t capture it, the yellowish picture is caused by unmatched white balance presetting
according to my experience, when you want to capture a moment like this,
switch the dial to S (shutter) mode, set the shutter speed to 1/80 or faster, using a flash will be an advantage, don`t forget to set the white balance to auto option
hope this advice help you with your problem
Nov 02, 2009 | Nikon D60 Digital Camera
My camera does all the proper functions but when you look through the lense all I see is black it does not show images. I take the picture and all you see is black, because that is what is in the view...
1. lens cap. had to say it, you know that! i assume it's off.
2. settings. once i had my lumix set on a certain white balance (dial, manual, menus) , and it let in so much light that all my shots turned out completely white ( i wasnt reviewing the pictures at the time). make sure you didnt put your camera on some setting that's blocking out light. try automatic by turning the dial.
3. try to reset your camera to factory settings using the menu system. sometime you get lost on the menu system and change an important finction that completely changes what you get when you take pictures.
Jan 31, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Printing Black and White pictures
hello,
i supose that you use compatible inks with your printer..
the problem is that the copatible inks are not good enough
you can also try to use another paper-diferent papers give diferent colours or you select another type of paper on the main printer software
Oct 31, 2007 | Epson Stylus R265 InkJet Photo Printer
Fuji FinePix A805 Digital Camera Logo
212 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
