Question about Canon Pixma MP450 All-In-One InkJet Printer
It sais there is no paper but it has. and it can not pull the paper it in the printer.
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Close the front cover.
Dec 21, 2010 | Office Equipment & Supplies
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
Im lookng for a service manual foor the mfc-866-dn. It makes a clicking noise and sais its out of paper and although I know what needs to be adjusted I would like to have instructions of how to open the...
check her but not sure this manual will give you enough info..
http://www.retrevo.com/support/Brother-MFC-8660DN-Multifunction-Printers-manual/id/386ci852/t/2/
Sep 20, 2010 | Brother MFC-8660DN All-In-One Laser...
The paper is stop in the printer
open the printer remove the toner and slowly pull the paper out. Pull in the natural printing direction of the printer, so if the printer pulls the paper from top-tray to bottom-tray when printing you should pull the paper from the bottom tray outwards
Jul 15, 2010 | Brother HL 2140 Laser Printer
How to clear paper jam in HL 5040 laser printer
Clearing paper jam in a printer is simple almost seven step procedure.
i. Put off the printer.
ii. Open all the covers/shutters on the printer (usually one in front or top and one at the back.
iii. Now pull out the cartridge carefully.
iv. Site the paper that has jammed and pull it out in the opposite direction of its movement. (Pulling the paper in the opposite direction is important for the printer mechanism).
v. Return the cartridge and press it firmly inside.
vi. Close all covers.
Power on your printer and you should be able to print again.
Dec 04, 2009 | Brother HL 5040 Laser Printer
Paper feed only works manual
I think you have a paper jam or some other tiny objects like a paper clip or the like blocking the ADF(Automatic Document Feeder) roller. You should open your ADF and check for anything obstructing the roller. If you see something just pull it off close the ADF and turn on the printer.
Good luck,
Sai.
Dec 02, 2009 | Brother HL-2070N Laser Printer
Won't pull paper through. starts to then paper
Just clean up your paper feed tires witch are below the printer. u have to see it when u pull out the paper try!
Jul 14, 2009 | Brother HL-2040 Laser Printer
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
Canon Pixma MP450 All-In-One InkJet Printer Logo
18 people viewed this question
old marine
old marine
