Question about Linkworld Electronic Co. Computers & Internet
Why does my electronic mouse stop working after not being used for a while?
    President:
  • 2,666 Answers
It automatically switches off to save battery power until you click a button.
Posted on Sep 06, 2009
I have a CanaKit Raspberry Pi 3. My USB mouse works fine until I plug an additional item into the USB above it.
You mouse may be using to much power. Sometimes while using older computers such as laptops and desktops newer technology consumes loads of power. Try using an older mouse and try seeing if you can plug camera in then mouse. If the mouse work and the camera doesn't it almost ensures a power problem.
May 22, 2017 | The Computers & Internet
Hi my name is ari . I have a windows Xp
@ari, there will always be a solution bro if have basic electronics background because sometimes a device may stop due to dust that stack inside on it or some terminal are disconnected due to time to time use of the device.use the green technology method bro. thanks and god bless.
Apr 24, 2014 | Logitech RX300 Premium Mouse
Hey there, my a4 Tech mouse stops and starts, with new baterries! It works fine but then it just konks out! for no reason that I can see! the keyboard works fine, but the mosuye works for 5 seconds, then...
You could try to re-sync it to the receiver and also look at anything that might block the receiver both physically like cords or books or electronically like too close to another electronic device. The phone cord to my multi-line phone actually interferes with the signal for my keyboard.
Aug 26, 2010 | A4tech Mouse
The left click button doesn't work:
There are two different things that would cause a mouse button to stop working. The first is a with the mouse itself. The second is software related.
The software issue may just need you to update your driver or reset the mouse button's assigned tasks to the default settings. To do this use either the control panel or if you have software for the mouse use that and reset to the default settings.
The hardware issue is a different story. When you push the mouse button can you feel the faint "click"?
If not then the problem is the mouse itself. It may just need to be taken apart and cleaned or it could be that the small "momentary switch" is bad. I have replaced them but to be honest it a real hassle and requires a lot of electronics soldering experience.
I hope this helps and good luck.
Jun 11, 2010 | HP Wireless Optical Mouse
My mouse just stopped working. I tried rebooting,
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Logitech Cordless Mouse
Logitech LX3 optical mouse has stopped working;
If you have tried the mouse on other computers and there is no light on the mouse it is not getting any power. Possible problems are:
1) The USB connector is bad or the cable to the mouse has a bad wire.
2) A wire inside the mouse has become disconnected.
3) The mouse itself is just bad.
Sorry it couldn't be better news. Thanks for using Fixya just the same.
Dec 02, 2009 | Logitech LX3 Optical Mouse
Spilt water on mouse. Now red light on
if the mouse is working properly then you might just want to leave it, is it a rechargable mouse?
If you do want to try and fix it , you could try carefully opening it, you should not need to use much if any force and then make sure everything inside is dry, using a hairdryer on low heat can be useful.
there is a chance the water has damaged the electronics of the mouse and so you might not be able to fix the problem.
Oct 30, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Dropped mouse in water
You will need to remove the batteries and let it dry for 48 hours. Having the batteries in the mouse while there is still potentially some water in it will damage the the electronics inside (if they are not already damaged) If after the 48 hour period your mouse still acts funny then you should simply replace it.
Sep 17, 2009 | Computers & Internet
Targus AMW15US wireless mouse
First are the batteries good?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 16, 2008 | Targus AMW15US Mouse
Dell wireless mouse
I had this problem, but only when my batteries were dead. Check the contacts on the batteries to make sure they're working. Are all the buttons failing too? It might be a broken microswitch (or whatever they use these days). It sounds like you're looking at a new mouse if it's not contacts. Unless someone else on this forum has different ideas.
Nov 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
24 people viewed this question
Top Linkworld Electronic Co. Computers & Internet Experts
David Payne
David Payne
Are you a Linkworld Electronic Co. Computer and Internet Expert? Answer questions, earn points and help others
