My Sharp CX68E4, 32" tube will not switch on, everytime i try to switch the tv on, it emits a static like sound from the speakers and the shuts off. The sound last for about 2-3 seconds before shutting down. the screen itself does not display any images or light. Thank you kindly for your assistance. Warrick
  • 378 Answers
Check the Horintal output transistor .
Posted on Sep 06, 2009
My sharp aquos has speakers on side of TV. the speakers are worn out and emit a low humming sound that disturbs the audio ? how can i solve the problem
A hum in a speaker is usually a bad connection on an audio jack, this allows interference to enter the audio signal stream Check all the connections and cables. Swap cables if you have the ability. If that does not reveal the source of the problem, you may have a component on the power supply that filters line noise that is going bad.
Oct 18, 2017 | Sharp Televison & Video
Audio Static on Sharp 32SC26B
Chances are your main board is bad, its where all the sounds are producted, a new board should correct the issue, its something you can install yourself with a screw driver, have the set unplugged for about a day before replacing the board so all the capacitors are discharged..you can get a new board at shopjimmy.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 09, 2018 | Sharp 32SC26B 32" TV
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
Strange buzzing sound
Hi there! If it is an anoying sound I would personally have it checked if still under warranty. It may be a bad coil or transformer in the power supply. Enjoy what you paid for rather than sitting with a fault that might cost you extra later on. Best Wishes and Good Luck, JUS004
Aug 22, 2009 | Televison & Video
Subwoofer with screech and static
This sounds like the output stage of the subwoofer amp has failed -- needs service...
Charlie
Aug 22, 2009 | Definitive ProSub 1000 Subwoofer Speaker
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Volume on tv stopped working
HIT MENU, GO TO AUDIO (SPEAKER PIC) SCROLL DOWN TO "2ND PAGE" AND SELECT SPEAKERS ON. AND YOU MAY NEED TO ALSO SELECT SBS ON
Jul 16, 2008 | Toshiba 36AF42 36" TV
Static 'white' sound
Good day.
Try to remove the cover of your unit and clean the tube with a dry cloth. try to look for the anode cap. the one tht is connected to your tube if there are holes in it. This causes the problem.
response is highly appreciated,
chris
Nov 21, 2007 | Sharp 32F-830 32" TV
No picture or sound
It sounds more like a shut down circuit problem if you can feel static from the face of the picture tube after it tries to start up. There are several things that can trigger a shut down condition on TV's. For instance, if there is no vertical deflection signal present, the set may shutdown to prevent a permanent line being burnt across the front of the tube. If the power supply wasn't regulating the B+ voltage properly, it would shutdown to prevent damage in the horizontal sweep section. Or if the horizontal deflection circuit was defective and allowing the high voltage to climb too high (say above 33,000 volts) then the sensing circuit would trigger a shutdown event. If any of the above sounds like gibberish to you then you will need to take the set to a professional for repair.
Nov 24, 2006 | Sharp 36U-F810 36" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
