Question about Hoover F5872-900 SteamVac Wet/Dry Vacuum
Rotating brushes don't rotate - Hoover F5872-900 SteamVac Wet/Dry Vacuum
    Sergeant:
  • 197 Answers
Check belt, may be broken or may have come off the brush bar and replace.
Posted on Sep 06, 2009
Spinbrush not working on eureka as1104
If the belt is intact, the brush roller ends may be so jammed (usually with hair) that it cannot rotate. Also, if the brush roller cannot rotate, the motor shaft may be rotating in one spot on the belt and eventually will burn it out. The solution in the case of the brush roller is to remove it and check for free rotation. If the ends are binding, the brush roller will have to be disassembled to remove debris.
Aug 10, 2014 | Eureka Vacuums
My brush is not rotating
Hi there, it's Jack at Dyson.
I'm sorry to hear your DC33's brush bar is not rotating. This is likely to be because the brush control on the cleaner head has accidentally set to 'Hard floors'. In this mode, the brush bar will not rotate. Please recline your machine into the vacuuming position, turn it on, and make sure the brush control is set to 'Carpets'.
I'm confident this will resolve the issue, as using and replacing the wand will not have any effect on the function of the brush bar. It's also important to note that the brush bar will never rotate when the machine is standing upright.
If you would like further assistance after you've checked the brush control is correctly positioned, please get in touch with us directly. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jul 21, 2013 | Dyson DC-33 MultiFloor Upright Vacuum...
Brushes don't rotate during floor cleaning
Check that no strings or other debris is clogging the brush wheels. If it isnt that check that the belt isnt broken connecting the brush to the motor. If that is ok, most likely the motor is blown and not turning the belt.
Sep 20, 2012 | Hoover F7425-900 SteamVac V2 Widepath...
Brush bar doesn't rotate.
Either the bearing in the rotating brush is bad and isn't allowing the brush to turn, or in the majority of cases, the belt is broken.
May 20, 2012 | Vacuums
Carpet brush not rotating
Did you check the drive belt for the roller? If not do so, the smell was the belt drive burning up.
Jan 16, 2012 | Kenmore Vacuums
The brush on my DC14 is not turning but the belt is in tact.
Sorry to hear you're having difficulties with your DC14. If the brushbar isn't rotating, you might want to check that you have the brush control set to the 'Carpets' mode. You might find it helpful to refer to the user guide supplied with the cleaner. In case you don't have yours to hand, here's an online copy:
http://media.dyson.com/downloads/us/floorcare/manuals/dc14_opmanual_usa2007.pdf
Please note that the brushbar will never rotate when the cleaner is standing in the upright position.
If you've checked the brush control is correctly adjusted and the brushbar will not rotate when you recline the cleaner into the vacuuming position, please get in touch with us directly so one of our experts can provide further assistance. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Customer Service
Aug 05, 2011 | Dyson DC14 All Floors Upright Vacuum...
Need to replace belt and cannot figure how to take it apart to get at the belt --- Took Screws off on the bottom but could not get to the belt
You have already removed the screws so lift the brush cover off. Then grasp rotating floor brush at both ends and lift. Clean strings,hair and other debris from rotating brush, paying close attention to the brush ends. Clean the debris from motor pulley and drive belt areas.Grasp old drive belt and remove from motor pulley. Place new drive belt over motor pulley and stretch other end over rotating floor brush in the space between the bristles. Place the ends of the rotating floor brush down into slots on the sides. Turn the rotating floor brush by hand several times in the direction of motor pulley. If installed properly, drive belt will center itself on rotating brush. Reposition brush cover and screw back into place. I hope that this helps you!
May 26, 2011 | Bissell 3591 CleanView Bagless Upright...
Brushes wont rotate
the belt has streached go to walmart and get a new one.
Aug 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F5872-900 SteamVac Wet/Dry Vacuum Logo
115 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
