Question about Viper Security and Remote Start System (basic install included)
Viper 690XV Installing with INT-SL Data interface module
I have a Viper 690XV which I am going to install using a INT-SL Data interface module. I am just not sure which wire from my cars data port goes to the Data interface module. Thank you, Rico
The number 2 pin on my cars OBD II is the data carrier which is then connected to the purple wire of the INT-SL Data Interface Module.
Data Interface Modules are becoming the standard for alarms and remote starter installations. These modules will make installations 75% faster and more accurate. I also recommend using Posi Taps to tap into your OBD II.
This a safe and 100% effective reversible method of connecting wires without crimping, cutting, or soldering. If you have any questions feel free to drop me a line or simply Google: "Posi Taps" by posi products. For Interface modules Google: "INT-SL". Good luck with your next installation. And remember the has endless resources providing you take time out to research them.
By the way my Viper install was a sucess.
Best regards,
Rico
Posted on Sep 10, 2009
Testimonial: "Great & easy to follow information"
Python same as Viper?
Hello Anthony,
This remote will not work with your system. It is only compatible with the Viper 591XV, Viper 690XV, Viper 790XV, and Viper 791XV.
Feb 03, 2014 | Directed Electronics 479V Remote Gen 2...
Viper 5701 not remote starting or unlocking
It's possible that you may have inadvertently locked the remote. Press "F" then unlock to unlock the remote. Then attempt to send your command.
Oct 15, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
My viper 5701 when cold will start with headlights staying on then the engine shuts off and when disarming the alarm the doors wont unlock. when the truck warms up then the system works properly.
This sounds like you may be having a problem with the interface module that is used in your truck and maybe not the remote start. Depending on what kind of truck you have and it sounds like you may have a GM truck... there is an interface that is used to control your locks and bypass the security system in the truck. You maybe having an issue with that.
Jan 07, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Is there anything needed to install a viper 5101 in a 2009 honda odyssey?
You will need some type of interface module to bypass the transponder in the key inorder for the remote start to turn on the van.
Dec 23, 2010 | 5101 LE 1 Way Car Remote Starter System
Back lighting for my viper 479v remote
you have to go in to the proramming mode of the remote to change this feature. you can access this by holding all 4 buttons on the remote at the same time. (or if you have the P button on the back you can hold it down by itself) you will hear 2 long beeps confirming the programming mode. at this time, you can change the settings by pressing 1 of the 4 buttons., each button will change a different function.
in no order------
1. Beep/vibrate or both
2. page or not to page
3.back light
4. hood, truck, or both
the remote will give 2 long beeps when it exits the programming
Aug 20, 2009 | Directed Electronics 479V Remote Gen 2...
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
490 people viewed this question
Top Viper Home Security Experts
Kevin Daniels
squeely
Are you a Viper Home Security Expert? Answer questions, earn points and help others
