Question about Samsung HCL4715W 47" Rear Projection Television
Convergence Hello, I spended around 150$ in getting a new tube for my projection and now a new problem arised - the tv convergence is not properly alligned , I mean all the three color are liked pinched from the middle and forms inwrd curve at all the ends. I dont know what to do - the company folks are charging 50$ for just the visitng charges. Please help me . My model number is SP- 43T8 , Please help - my email address is rohitbansal@msn.com
    Genius:
  • 1,030 Answers
You have a samsung? hcl4715... your convergence chips have most likely blown...sorry..
Posted on Dec 08, 2007
Convergence problem panasonic televison
Unless you are familiar with TV systems, this is best left to a professional. Rear projection systems typically use three separate image sources (red, green and blue) to display the picture. If any of these sources is misaligned, the convergence problem arises. It may be something as simple as a bump while transporting it or some loose screws but given the voltages in the back of TV systems, it is much safer to get a TV engineer to make the proper adjustments for you.
Apr 14, 2014 | Panasonic PT-53WX42 53" Rear Projection...
I have a philips magnavox 64" rptv, "99", model 9p644c. The picture is real dim. a friend gave it to me, but don't want to spend a ton of $ if I can buy one cheaper. Doe's it just need a bu
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Jan 21, 2013 | Philips 9P6444C 64" Rear Projection...
Kp51ws510 posso usar o stk392-150
  • Screen looks 3D
69189a5.pngSOLUTION
Oct 03, 2012 | Sony KP-46WT510 46" Rear Projection HDTV
Mitsubishi rear projection picture that has a blue/green tint
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
  • Screen looks 3D
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
69189a5.pngSOLUTION
Dec 01, 2011 | Sony Televison & Video
Poor colour balance
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 17, 2009 | Hitachi 46F500 46" Rear Projection...
Convergence Issue on Toshiba TN50X81 - Service Manual & Parts Source?
Replace the convergence IC's - P/N STK192-110 with part STK192-150 or 180. Then you can go back in and make the detailed convergence settings and get your picture back in alignement. Also check the flame-resistant resistors around the ICs to make sure that none of them have opened up.
Jan 11, 2009 | Toshiba TN50X81 50" Rear Projection...
5yr old philips rear projecter tv color bad 50inch
  • Screen looks 3D
Dec 01, 2008 | Philips 9P5034C 50" Rear Projection...
Picture quality
Have you tried adjusting the convergence yourself?
Oct 15, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Projection TV convergence problem
Get it fixed, because this is a simple repair. One of your convergence IC's has burned out and needs to be replaced. A good tech can fix the set in-house in about an hour and a half, and I charge $150 when I fix a set like that but shops in your area will vary so ask around. If you have a satellite receiver or a cable box, the changeover in 2009 should not affect you.
Sep 04, 2007 | Toshiba 55H70 55" Rear Projection...
Convergence Problem?
It's hard to tell for certain, but from what you're describing this sounds like the degaussing mechanism of the TV is either malfunctioning, or that there's some electromagnetic field around that keeps screwing with your TV. This could be caused by speakers, lamps, or any other electrical device. In any case don't hurry to spend 400$ on repair, it's been only three days, and there's a nice chance its not the convergence, or that you'll be able to find someone in your area that won't overcharge you. If there was any device added to the mix around the TV lately, remove it, and try plugging out your TV over night. If turning it off and on a few times won't solve it in the long run(that's the way you make the degauss mechanism work), you should look again into repair options in your area. Good luck
May 17, 2006 | Philips 60PP9352 60" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
