Question about Dryers
My drum stopped turning on my zanussi tumbler drier. Not sure if something got stuck somewhere in the drum. Is it easy to take apart and fix or should i leave well alone.
  • 37 Answers
Depends how handy you are lol, make sure its unplugged from mains remove the back plate on machine then you can see if there is any clothes jammed or maybe the belt has come off or broken
Posted on Sep 06, 2009
Testimonial: "not bad...shall try"
Zanussi TC7114W not spinning
The belt may have failed.
Sep 22, 2014 | Zanussi Dryers
How easy is it to replace the rear bearing on a Zanussi TC7102W Tumble Drier, do I take the whole drier apart to do it? Thank you
you first remove the top cover,then the front cover then the drum belt and drum come out the front,and the bearing can then be accessed
Oct 14, 2010 | Dryers
Zanussi fs 1555 w machine stopped during cycle now drum will not turn
If you cannot turn the machine by hand then it may be an idea to see if the drive belt has snagged around the back end some how take a peep with a torch thru. top.if the belt looks ok it may be that something has got stuck inside the drum.Sometimes socks get stuck between the front of the drum casing and the drum shine a torch around the front by the door seal and see if you can see any objects jutting out if you can be careful and try with a vice grips to pull out if no joy it sounds as if it will have to be a tub out job.Sometimes objects like coins can be fished out thru the back where the heater sits but still a lot of work to get down there.Body of machine has to be split for access.
Good luck
May 04, 2010 | Zanussi F1245W Front Load Washer
Drum stopped turning mid cycle, think something is stuck, have opened up backbut cant access drum
If there is no removeable cover on washer, then you have to remove therear half of the cabinet to gain access to the drum etc.
Jan 17, 2010 | Zanussi ZWF1430W Front Load Washer
I have a Zanussi ZWF1241W and something is stuck in the drum. The drum does not spin freely and prior but does not have any play. What is the best way of checking this and getting the obstruction out....
It was a sock wedged between the lip of the spinning drum and the outer (stationary) drum casing. I managed to ease it out with some pliers - rotating the drum and pulling. Be careful though not to nick the door seal (as I did). It may be a better strategy to get the door seal off and then remove the obstruction. I'm about to find out how easy/hard/fiddly it is to get a new door seal onto this machine!
Oct 07, 2009 | Zanussi Washing Machines
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TDE4234W Tumble drier noise
Probably the gliders is worn.
Jan 31, 2008 | Dryers
How do i change the pully on my maytag sde2606 elec dryer
i wold first look to something in the drier drum glides not letting it turn easy enough in my opinion the pully its self is not your culpretits its doing its job real well or it wouldnt be squeeling something is stopping the drum from turning with the drier off check it by turning it by hand feel the resistance thats where the promblem is something jamming your drum
Dec 29, 2007 | Maytag SDE2606 Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
