Motorola SURFboard® SB5101 Cable Modem
Problem for Motorola SURFboard® SB5101 Cable Modem
Everything is connected but the receive light is
By daydreamcac8 on Sep 06, 2009
everything is connected but the receive light is flashing and the pc/activity light is orange.All other lights are off
Best Solution
posted on Sep 06, 2009
Very Helpful)
bob_computer
Rank: Guru
Rating: 87%, 1207 votes
On a on a surfboard modem would mean that you are only connecting at 10 Mb as opposed to 100 Mb
If you have a router it may well be a setting on the router.
otherwise I would look for a cable fault or network setting.
In theory it will not make too much difference if you only have a 5mb high speed connection.
In practise it may mean slightly slower pages on the INTERNET.
Start with checking you network settings for you wired connections more so in the properties for your Ethernet card.
If you can, look for a FULL DUPLEX setting and set that to auto.
I would also look at maybe replace the network cable and check that you are also plugged into the correct ports on any router.
eg. modem to router is the yellow Port or WAN
router to computers is usually black ports or LAN (usually 1 to 4)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Motorola SURFboard® SB5101
Questions and Unsolved Problems for Motorola SURFboard® SB5101
Do you recommend Motorola SURFboard® SB5101 Cable Modem?
Answer
Answer
motorola cable modem sb5101 the receive light blink an the same as the send light
Answer
power come on receive come on but not the othere light don't come on
Answer
I need a circuit diagram for my Motorola SurfBoard SB5101. Specifically, I need an alternate... (More)
Answer
I haveSB5101 SURFboard and I want to know if I can run a test on it without having internet... (More)
Answer
setting up an security login password password
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola SURFboard® SB5101...:
Top Modem Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Modem Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
