Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Same thing i have the same problem with the gateway SX2800-01, unboxed today. loud clicking noise, computer doesn't see HD. Now stuck with $500 paperweight. GW tech support not very helpful
  • 508 Answers
If its making a loud clicking noise i would guess that the hard drive got jolted hard while shipping if possible send it back and get another one or if you have another hard drive put it in install windows and discard other drive very rare for them to get damaged during shipping(maybe you can get them to just send hd(hard drive)and drivers instead of whole computer!!!
Posted on Sep 06, 2009
  • Aaron Tonning Sep 06, 2009
    if its making a loud clicking noise i would guess that the hard drive got jolted hard while shipping if possible send it back and get another one or if you have another hard drive put it in install windows and discard other drive very rare for them to get damaged during shipping(maybe you can get them to just send hd(hard drive)and drivers instead of whole computer!!!
Gateway ne522 series laptop is stuck on reverting changes
you need to repair windows before updating again,for now you can force shutdown then boot in safe mode and delete the current updates to stop the updating
Sep 28, 2015 | Gateway NE52204u Silver 15.6" Notebook 1.5...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Noise from front wheel - yamaha TDM 900
it does sound like it could be a bearing, and have that looked at soon.
Apr 10, 2010 | 2003 Yamaha TDM 900
Clicking noises and no recognition on computer
The read mechanism is stuck that is it is unable to move to the next section on the magnetic platen disk inside the hard drive \
It has come to the end - of - Life and need replacement.
To recover your data before it completely dies is to put the drive into a usb case and connect it to the computer that has a large capacity drive and backup the drive contents. You will have reload Windows to the new drive.
Apr 06, 2010 | Western Digital My Book Essential Edition...
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hard drive won't mount on my mac bookpro
say goodbye to them, you might not sleep today but you'll forget about it
when noise happens the needle isnt reading the disk, unless you pay $500 to a data lab to recover it "if they can" usualy they cant
Mar 12, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Time for physical format ???
Formatting such a large hard disk will take a long time, especially if you do a full format (not a quick format).
Just let the computer do its thing, don't turn it off.
Jan 06, 2009 | Buffalo Technology DriveStation HD-HC500U2...
Gateway gt5220 beeping noises, fan on.
What may be happening is that files are corrupt as a result of a HD failure. This is not that uncommon. It has happened to my computers causing strange beeps and often repeated clicking noise coming from the hard drive. HD failure can happen anytime; when booting up, while the computer is running. The only way I've found to fix this is to buy a new hard drive and reinstall the operating system and programs you typically use.
You may be able to recover files from the ailing drive however. After you get the new hard drive working with your newly installed operating system and all is working, you can setup the ailing drive as a slave while setting your new drive as a master. You need to power off the computer and consult the data sheets for jumper settings.
This will allow you to boot up and access your old HD as a spare. If your lucky the data files, pics, music and documents you created will be in a region of the hard drive that isn't corrupted. Be prepared however to expect some unrecoverable files. If there is physical damage to the drive mechanism like a stuck read/write head then you may be totally out of luck. I have in some instances been able to unstick the HD by giving it a sharp rap on it's edge and even opening it to push the head free. Success for such a radical procedure is rare, but when it works, you have enough time to copy files over before enough dust collects on the exposed HD.
Assuming your able to access the old HD as a secondary drive, copy all of your files over to a backup directory on the new HD. I would recommend an expternal backup HD that can be used to automatically save your files before the next failure happens.
Nov 30, 2008 | Gateway GT5220 PC Desktop
Loud noise
Typical problem in most computers, the fan is experiencing a "burn out." This means there is either something caught in the fan causing it to create noise, or the motor is going bad. there are two fixes for this problem.
1) open you computer's case according to its manual and remove the system cooling fan and give it a thorough cleaning.
2) you may need to replace the cooling fan with its recommended replacement model.
Hope this helps!
Jul 08, 2008 | Gateway 506GR PC Desktop
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
300 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
