Question about Canon BubbleJet i560 InkJet Printer
Red line I just precis the same problem on my printer i560 with a red line on the end that the paper when I print out photos
  • 88 Answers
Im think its a sofware problem
if you have some question
add me in my yahoo meseenger jeffrey_bunxo
i hope i can help you
Posted on Sep 06, 2009
Distorted printing on i560 printer
Double-click print centre icon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Hope this helps
Regards
Apr 16, 2009 | Canon BubbleJet i560 InkJet Printer
I 560--photo printing on 4"x6" paper
You should be able to do this in print preferences. Open up your general printer box by clicking on Print. Select print preferences then page setup then select page size and a list of sizes will appear just select 4x6 and then paper type, press print and you have done it.
You might be able to get a manual from the Canon website or 'google' for the one you want.
Please remember to rate this solution.
Nov 05, 2008 | Canon BubbleJet i560 InkJet Printer
Canon I560s printer
Was this the problem prior to changine the cartriages? If not check the contacts between the machine and the cartriges. there may be tape, ink, papaer in between.
Jul 03, 2008 | Canon BubbleJet i560 InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
HP 950 PHOTO PRINTING PROBLEM
try to check the paper size from the printer and be sure that the paper with the same size...
the check out if the printer pick up the paper correctly
Regards...,
Feb 17, 2008 | HP PSC 950 All-In-One InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon Pixma MP810 Full Page Photo problem
Check your print settings and run an allignment check.
Sep 27, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Red line on last quarter of photos
I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
29 people viewed this question
old marine
old marine
