Question about Head LOT OF 4 ADJUSTABLE HEAD EMERGENCY LIGHTING FIXTURE
Mx7000 how do i wire it
I have a MX7000 code 3 light bar and 14 wire coming out of it i want to wire each light up to own individual switch right alley lights left, alley lights, high speed rotators, rear and front strobes i want wired on the same switch, osolating lights and take downs thanks
  • Anonymous Mar 29, 2014
    blowing fuses
I have a mx7000 lightbar but the switch for the front flashers will only go on if the the main lights are on any ideas on how to resolve this issue.
Posted on May 04, 2010
Bang olufsen mx7000
Check for any loose solder terminals at its video output card. This card can be located at the back of the CRT, will directly plugged on to it. Re-solder all the suspected solder terminals, by applying a little more solder. The fault can be categorized to 'sigle color predominant' screen.
Gopakumar Gopalan Google
Feb 12, 2014 | Televison & Video
I have one light in a room w/ 3 light switches to operate it. We want to eliminate one of the switches (has two 14-2 wires going to and coming from). The other two switches have 14-3 wires coming from...
I can help you with this problem but will need to confirm some details. Please confirm that the switch you wish to eliminate has two twin cables running to the switch mech. I'm not sure what you mean by two 14-2 wires. I am guessing you simply mean two twin cables. I'm guessing that the two twin cables have the same coloured building wires coming out of them. If so, remove these wires from the switch and join the same colours together. The other two switches will simply now work on a two way basis.
Mar 14, 2011 | Electrical Supplies
I have a uniden bearcat scanner 30 channel i would like to know if it is possable to add any software or chip to make it able to pick up aircraft frequencies ? ...
Sorry, but it's been a long time since scanners could be modified to extend or change their frequency coverage. The AIR band in your BC350C allows you to monitor commercial, private, and some military aircraft. If you want full military air coverage though, I suggest that you look at the reasonably-priced BC370CRS.
Bill B.
Listening in since the 60's
Jan 29, 2011 | Uniden BC350C Base Scanner
Need a manual for prixma Mx7000
The link below is to the product page on Canon's site for that particular model of printer. If you go to the Drivers and Downloads section you will be able to download the manual and several other guides for the product.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15651
Robert from Blitware
Jun 18, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I want to wire a 3 way switch with multiple lights between the switches. The easiest route and least wire used is power in at switch then to lights then down to second switch. would i use a 14/3 from...
You have to run the 3rd wire all the way to the switch, whether it hits any lights or not, I have seen electricians pull a single wire in to the box with the 14/2 and that would be the jumper. This will work on any lights, and the lights only need the 2 wires, It is just the switch that needs the 3 wires. Good luck.
Feb 22, 2010 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
Problems getting PS3 installed
Hi to be honest it should work straight away, sometimes if the display settings are not matching it can cause problems, ie that the PS3 is set not to show 1080i 720, etc etc you may not get a picture. have you got a different TV you can try to check the settings on, if so enable all of the display settings and try each one
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Head LOT OF 4 ADJUSTABLE HEAD EMERGENCY LIGHTING FIXTURE Logo
1,353 people viewed this question
Top Head Electrical Supplies Experts
john h
downhille
Ted Maxwell
Are you a Head Electrical Supply Expert? Answer questions, earn points and help others
