Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER5755QAS Electric Oven
I replaced the bake element which had burned out. The process was very simple and I know it had to be done but it is still not working. I tryed the broiler just to see if it would heat and I get nothing. Is there a reset or fuse or something else I need to do to get it going again?
    Problem Solver:
  • 6 Answers
Part number 12001656 needs replacement. This is the sensor. I have had it replaced twice now and Maytag doesnt care
Posted on Dec 20, 2007
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
Maytag Oven model MER5755QAS trouble heating up
your bake element could be burned out & the oven is trying to get to temp with the broil element only. see if it is getting warm or if it has a burnt spot on it. if it seems to be ok, you may have a bad oven sensor. the oven sensor should have a reading of at least 1100 ohms. let me know if i can be any further help.
Oct 13, 2009 | Maytag MER5755QAS CleanDesign Electric...
I have a model MER5755QAS. Oven/broiler not working right.
Sounds like you may be getting only 110v to unit. After unplugging, Check for any burnt wires around terminal block or around elements. Also first check if breaker may have half way tripped. Cut breaker for stove all the way off and then back on. The bake element may have partially tripped the 220v breaker thus only sending 110v to unit.
Oct 31, 2017 | Maytag MER5775Q Electric Kitchen Range
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
on a 220 volts stoves when the electrissity drops to 120 volts thats what it oven element wires most be check for power, if it's getting 220 replace the element.
Sep 16, 2008 | Maytag MER5755QAS CleanDesign Electric...
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven not heating
if that hi limit is bad or tripped you wont get heat.the hi limit should sit near the heater if not in it.if you find this is tripped your thermostat could be faulty.from the schematic try to trace the wires from the heater to the hi limit and then jump it out.let me know.
Dec 11, 2007 | Maytag MER5755QAS CleanDesign Electric...
Electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Apr 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Burned out element
When the element burned in 2 iot may have tripped your circuit breaker.
Check your breaker box and look for a 40 or 50 amp breaker and flip it off and then back to on. If this doesn't help then a tech. may need to be called for service.
May 05, 2007 | Maytag CWE4800A Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
327 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
