Question about Dell Latitude D530 PC Notebook
Getting error upon startup...only desktop background is showing. (cidaemon.exe - 0x008f0660 & route.exe - 0x00930660 errors are coming)
    President:
  • 2,600 Answers
Sounds like the files explorer is failing to load. Boot the computer with the install disc and choose repair. Follow the prompts.
Posted on Sep 06, 2009
Error code c-c 152
I think your problem comes from the scanner, try the operation if you have anotherPWB-C when you turn on the machine.
5/16/79 CC151: Error upon startup ROM contents (MSC)
5/16/80 CC152: Error upon startup ROM contents (Scanner)
5/16/81 CC153: Error upon startup ROM contents (PRT)
5/16/82 CC154: Error upon startup ROM contents (PH)
1 Check the ROM version. -
2 Rewrite the firmware. -
3 Replace the Appropriate board.
Apr 25, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
After installing oracle 8i after booting the desktop it shows strtdb80.exe error how to remove this error
Press the windows key and the R key on your keyboard at the same time,
(The windows key is the flag key usually between the ctrl and alt keys)
In the Run Menu type msconfig and click ok
In msconfig, select the startup tab
Find the program strtdb80.exe in the list and uncheck it
click apply, Then ok
Upon the next boot you will get a different message saying system configuration was changed, To prevent this from re-showing click the don't bother me again option in the bottom left of the info box and click ok.
Aug 28, 2011 | Computers & Internet
I keep getting a service hang report, it says HP CUE DeviceDiscovery failed upon startup. When I go to windows reports and solutions it says a minidump.MDMP error.
change the following services.
Click on the Start button, then type "services.msc" in the "run" dialog box and click OK.
in case of vista/win7 type it in "start & search" box(you can find it once you click on windows logo)....
Set as "Automatic" the startup type for:
-Windows Firewall
Set as "Manual" the startup type for:
-HP Network Devices Support
-HP CUE DeviceDiscovery Service
you can right click on the particular service and click on properties....then change the startup type....
this issue will fix for sure....
pls do rate if its found useful...
Apr 02, 2010 | HP Hewlett Packard Pavilion A6200N PC...
Dwwin.exe-application error. The instruction at "0x0013ff7" refrenced memory at "0x00000013". The memory could not be written. The computer will not load any icons on the desk top just frozen their
dwwin.exe is Microsoft Application error Reporting. You may have a problem with a background program starting at Startup. May want to look at items on the Startup tab in msconfig.
Start,
Run, then type msconfig remove any program that you do not need at the start up or the last one you installed
Sep 11, 2009 | Computers & Internet
Rundll32.exe error
what that means is that your computer is sending shutdown commands to all the apps running in the background and they arent responding fast enough. its nothing serious or anything that will cause problems BUT if you want to get rid of it, do some googling on cleaning up your computer's startup routine with msconfig. turn off everything but your antivirus and the problem will most likely go away.
Apr 26, 2009 | Dell Inspiron 530s Desktop Computer
Computer startup
can you try right clicking the desktop and click view on the pop up menu, then under view click show desktop icons.
Apr 17, 2009 | Computers & Internet
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
Upon startup (logging into account) background image loads on desktop but no control, no icons, no menu...nothing. Ctrl.alt.del fails to do anything....? help?
HI,
It is may be due to a virus. just check in task manager Is something is running continuously. If so kill that process. If not from task manager take File ->New task and in open window type .. it will give one error massage click on ok the it will load all on desktop.
Dec 21, 2008 | Computers & Internet
I am unable to do anything on my computer
you got virus, and Trojan on your laptop.
need to go buy a good antivirus software. i.e. symantec, McAfee, etc..........
ask the sales person in the store.
scan the laptop.
Nov 14, 2008 | Toshiba Computers & Internet
Wierd problem
It sounds like a program you have installed is having an error on startup. Dwwin.exe is the executable for Dr. Watson, an error reporting program that comes with windows. Errors like this usually raise a red flag with me, and the first thing I always do is scan for spyware and viruses. If you don't already use them, I would suggest using Spybot - Search and Destroy, as well as Ad-Aware SE for spyware, and Panda Activescan and Trend Micro Housecall for online virus scanning. (using multiple programs is always a good idea so nothing slips by.) Next, I would check your startup programs to see what is there to determine what could be generating an error. Your computer could also be missing critical updates that could solve many problems (as well as scan for malicious software if you are using windows XP). You should run windows update through the menu in internet explorer. Methods for these solutions depend on which operating system you are using. If you need any further help, give a list of all your startup items and which OS you are using and I (or someone else) can give more detailed instructions.
Nov 20, 2006 | Dell Dimension 4600 PC Desktop
Dell Latitude D530  PC Notebook Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
