Rank: Guru
Rating: 86%, 7649 votes
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Screen looks 3D Colors don't line up One or more colors
can't be adjusted when using the convergence menu. Screen is bowed or warped.
Here is a quick test.... Using your original remote go-to the TV settings then
go to the convergence section. Try to adjust the red and then the blue
convergence. You should be able to move them up, down, left, and right. If you
can't move them in all directions your convergence chips are bad and should be
replaced. This is a common problem. Solution #1 you need to replace the
convergence chips and convergence resistors. Check the site
www.TvRepairKits.com. They have put together a kit for most models. If you
don't see kits for your set send them a quick note under the contact us button
please, you will get an answer within 24 hours or so.(excluding holidays Good
Luck
Techman
Your TV most likely has one of two possible problems. Problem #1:
Convergence Chip Failure ( common problem ) Here are some of the most common
symptoms and example photos of a convergence problem Screen looks 3D Colors
don't line up One or more colors can't be adjusted when using the convergence
menu. Screen is bowed or warped. Here is a quick test.... Using your original
remote go-to the TV settings then go to the convergence section. Try to adjust
the red and then the blue convergence. You should be able to move them up,
down, left, and right. If you can't move them in all directions your
convergence chips are bad and should be replaced. This is a common problem.
Solution #1 you need to replace the convergence chips and convergence
resistors. Check the site www.TvRepairKits.com. They have put together a kit
for most models. If you don't see kits for your set send them a quick note
under the contact us button please, you will get an answer within 24 hours or
so.(excluding holidays Good Luck
Techman
