Question about Fitnex T50 Treadmill
Jazfit t50 EO error code
EO code in manual says its the safety magnet strap is missing. I have since lost that and tried using a normal magnet but with no luck. Maybe the cable connecting panel to base is broken?
Wall safety strap for Alex 1500 dresser
You can actually use a length of web strap (put a metal washer between the screw head and the strap).
Or, you can use some "steel hanger strap":
http://www.homedepot.com/p/Oatey-3-4-in-x-25-ft-Galvanized-Steel-Hanger-Strap-339292/100344678
Or, they actually have kits for this:
http://www.homedepot.com/p/QuakeHOLD-7-in-Steel-Furniture-Cable-2830/202214435
Jun 26, 2014 | Lusso Nursery Alex 1500 Collection 4 in 1...
Lost magnet treadmill
Hello. In the mean time you can use a fridge magnet to get you back on the machine. You might need a strong magnet, so if the first one doesn't work keep trying.
try googling the brand of machine you have to purchase parts or try eBay under treadmill safety keys.
GymWorld.net.au
Jan 10, 2014 | Exercise & Fitness
How to bypass magnetic key on gold gym 450 treadmill
If you need to purchase a new safety key that was designed to work with your Gold's Gym machine, here is a link to one that is listed for seven models of the 450. But please make sure that your exact model is listed to ensure compatibility.
Safety key 6043675 Fitness and Exercise Equipment Repair Parts
Nov 04, 2012 | Golds Gym 450 Treadmill Drive Motor
I bought a used precious planet cradle swing and it is missing one of the safety straps. How do I fix that?
There should be holes on the bottom of the swing for the straps to go through. Try to find some other unused strap and use that instead. Maybe a strap from an old bag or backpack. You can also scout your local Salvation Army or some garage sales for items with straps in them that you can use.
Oct 28, 2011 | Fisher Price Precious Planet Cradle Swing
New fitness treadmill TS01 that reads EO how do i reset it
What do you do when EO shows up on your treadmill. We have tried to put the safety switch back and also replug the treadmill into AC power directly as suggested in the manual but it hasnt solved the problem.
Jan 16, 2011 | Exercise & Fitness
Hello I have a Nordic Track A2050 treadmill and it has worked flawlessly till today, The unit was open (unfolded) and I wanted to close it because I nearly killed myself tripping over it, so I turned it on...
Hello there, The machine is attempting to do an incline calibration. Keep the unit lowered as you have it, reinstall the safety key, allow the unit to go all the way to the top and then all the way to the bottom. The machine will stop when at the bottom and the screen will go back to normal. The machine will not overtravel the incline motor and damage it. Just let the calibration finish the procedure and you will be fine.
Good Luck! Tim
FYI this will happen anytime the safety key is removed while the incline is moving on nordictrack brand machines.
Jan 11, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hi, have lost the manual for my treadmill York T500 treadmill. Error 7 keeps coming up...what does this mean please?
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Apr 20, 2009 | York Barbell Home Use Fold-Up Treadmill
I purchased a reebok s9.80 from sams club,most all the paperwork and wrences were missin. how can i get info on this particular model?
I just bought the same thing from sams club and am having the same problem.....I can't even get mine to turn on! Can anyone help?
Feb 26, 2009 | Reebok 8700 ES Treadmill - Silver Service...
I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Jan 29, 2009 | Exercise & Fitness
Fitnex T50 Treadmill Logo
389 people viewed this question
Top Fitnex Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitnex Exercise and Fitnes Expert? Answer questions, earn points and help others
