Question about ASUS MB M3A78-EMH HDMI RT Motherboard
Monitor senses cpu, but will not display picture
At first USUB worked, then switched to HDMI, all settings seem right, monitor goes into power save mode reguardless of activity. Tried switching back to USUB and same problem occurs. A different monitor has same issue.
  • lorenzo carolus May 11, 2010
    right click on your desktop.go to properties.in properties go to the screen saver tab .under the screen saver saver tab you will see something called power.click on it.change your monitor sttings there
    Problem Solver:
  • 18 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
auiioo13
Posted on Sep 08, 2009
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Acer pc and lg monitor blank screen says power save mode on start up, anyone know how to fix this?
Actually during start-up there is a slight delay before the HDD & OS is detected by the CPU. Normally all monitors slip into power saving mode within 10 secs of inactivity of either mouse or keystroke. This inactivity is read by the monitor which promptly switches to power saving mode. However the moment the HDD LED starts blinking, the monitor wakes up & starts displaying. This power saving mode in most of the flat screens is only associated with movement of mouse or keypad. This does not register till the CPU starts up & thats why the monitor switches over to power saving mode till it starts receiving signal from the CPU.
It is a normal behaveour, so don't get worked up over it, plus you can always hit the Auto set feature on the monitor after booting the PC completely. ( I think the time out for the monitor to enter power saving mode is only 10 secs). Hope this helps.
Oct 08, 2012 | Computers & Internet
Settings brightness
Hi which monitor are you using? Connect a different monitor to same system to see if that monitor works correctly with that CPU with same settings or connect your monitor with another CPU which is working properly with different monitor to pinpoint exact problem first. Any monitor if gets old will have such problem. If monitor is okay then you can check if display driver is present or not by going to See how many output connections your monitor has if it has multiple input connections like display port, HDMI, DVI, etc, you can try connecting to different ports if your CPU supports to see which connection gives what type of display.
https://youtu.be/lOT4zLqMOWQ
This video has partial information about display settings. You can right click on desktop and select properties and make it to default settings.
Dec 19, 2017 | Samsung SyncMaster P2250 22 inch LCD...
No display, light goes green but on screen says no connection then goes yellow for standby tried both DVI and VGA so now linked my pc to my tele via DVI to HDMI and works fine anyone know what this could...
here is the simple test to detect hardware malfunction.
on every monitor these days whether its CRT or LCD already programmed inside self test.
detach your cable data to CPU and power on your monitor. if its displayed self test on your screen mean its OK and something wrong with your CPU, could be VGA error.
if its just black display mean some is wrong with your monitor.
if you post more detail maybe we in FIXYA could help.
thanks.
Mar 11, 2011 | Hannspree HW191D LCD Monitor
L1718S won't come on
hi
my dear LCD monitor dosn't have power saving mode it's from your CPU
may be you have problem with your Display setup from your CPU
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
Computer screen goes into "digital power saving mode"
You should be able to adjust the settings on the monitor to prevent it from going into power save mode, or at least to delay how long it takes before it goes into power save mode. Press the menu button and look for settings that might disable or change power save mode.
Also, does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your newer monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PC's video card/motherboard, not the monitor.
Hope that helps. Good luck
Feb 15, 2010 | LG L1915S 19" LCD Monitor
My aoc keeps shutting off like it's going into
if the cpu unit is working while these is happenning and you just check all the setting that has to do with the display and you fine it ok, then it the monitor itself that has a problem have it check by a monitor technician
Nov 22, 2009 | AOC Monitor
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Monitor automatically clicks into power saving mode
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
ASUS MB M3A78-EMH HDMI RT Motherboard Logo
174 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
