TV, KV-TF21M80 TURN JUST A SEC AND BACK TO STANDBY
BEFORE I REPLACE FBT AND HORIZONTAL OUTPUT, AFTER THAT WHEN I TURNED ON V, KV-TF21M80 TURN ON JUST A SEC AND BACK TO STANDBY MODE,
  • 378 Answers
Try to pull out first the vertical IC, then switch ON the TV,If the Tv is On it may be the Vertical IC problem change it. If Still the same before pulling out the V IC. check the low voltage side for any diode leak.
Posted on Sep 06, 2009
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Standby light
This problems is cause by FBT-Flyback tranformer the big black block of plastic with a red wire with a cap hook to the CRT(tv tube) and the "H" horizonal transistor left side of the steal plate cage of the big black block of FBT.U have soldering tool,and solders?Resolders the FBT,and "H" horizontal transistor will help to stop this problems,if those parts are still goods,not dying.Or might help just leave the tv on 4 or 5 hours,the heat of the tv could heal the cold solders itself.
May 10, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Kv-32fs16, no picture or sound , red lights flash 4 times
Hi
In sony tv`s the 4 blink code(sony error codes)usually means that there is a vertical deflection problem.
It is often caused by a faulty vertical output i.c and/or related components. If you feel handy with a soldering iron let me know and i`ll help you with it.
Hope this help Merry Christmas
Dec 17, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony KV-34HS420 shuts of and stand-by light blinks
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Source
Sep 01, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony KV32 FX65B trinitron stopped working.. i took it to a technician and he said i needed to replace the FBT (fly back transformer) along with two transistors. I just replaced them and when i start...
When it is shifted to right vice versa, it indicates a distortion on the horizontal output. Try replacing all the capacitors around the horizontal output area with the same original value. Make sure the horizontal output transistors you replace hasn't started going gone bad already if you know how to check them. Them dimness in the picture is caused by the horizontal output not putting enough high voltage to the CRT. Look for leaking capacitors too. Also replace the resistors around the horizontal output, they may have burnt out or changed in value from overloading cause by the malfunction of the flyback, and the transistor.
Jun 27, 2009 | Sony FD Trinitron WEGA KV-20FS100 20" TV
32gt660 (ctc187cn3)
The flyback is availabel as part number 223952-rep from tritronicsinc.com at a cost of $29.00 US.
Please replace the horizontal output transistor wih the correct one as well: Part number 223942 available from above at a cost of $15.49
Dan
May 20, 2008 | Sony KV-32FS13 TV
Sony trinitron KV-32FS13
The HOT transistor is shutting it down. (horizontal output transistor)
it cost about 8.00 for the parts and 100 for the labor.
you will require help from a tech.
Jan 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV-27V40 27" tv (Dec 1998)
Sounds like you have a short in your set. Probably a shorted horizontal output transistor. You need to have a tech check it out and give you an estimate for repairs. Stargazer
Aug 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby light flashing
This is possibly a sign that there is a fault condition. Short circuit line output transistor
Jan 23, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
