Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman opener is not responding to limit switch on the down phase-- it continues down until the door goes full closed position and auto reverses. any suggestions? I have replaced the limit switch and the receiver logicboard assy.
    President:
  • 3,197 Answers
On the side of the motor unit you will find the 'down limit' control. Turn this in the opposite direction of the arrow printed on the cover. It would be a good idea to take the cover off and watch the limit assembly while you are doing this to make sure it contacts before the door hits the floor.
Posted on Sep 07, 2009
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
After the door is fully open, the motor stalls when closing. It trys to continue to open instead of close and the screw drive carrage jams against the "open" end and stalls. I have to unplug it to get it...
It sounds like you have a broken or missing "upper limit switch". There is one for the down limit and should be one for the upper limit. If it is defective or missing the openers 'brain' will not tell the motor to reverse direction.
Nov 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster tries to close instead of open door
Remove the chain from the sprocket and then run the motor until the sprocket turns clockwise and stops. With the door in the closed position and everything attached to it, replace the chain and tighten. This will get everything back into sync. You will most likely have to tweak the up and down limits a bit. Do not over tighten the chain. It should sag just a little.
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot get chain drive to open or close position
What you need to do is adjust the down limit in the opposite direction of the arrow printed on the cover until the door stops before reaching the floor and the same with the up limit. Now that you have the door stopping in each direction you can tweak those adjustments until you have it right.
Aug 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not continue to open garage door.
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens after closing
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2HP Door Opener won't stay closed
Loosen the chain and run the opener until the sprocket runs in the counter clockwise direction and stops. Now with the door in the open position replace the chain. This will get everything back into sync but I hope you remembered where all those controls were. You need to put them back in their original positions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
The door reverses back to open position instead of closing
SOUNDS LIKE A SENSITIVITY ISSUE UNHOOK THE DOOR AND TRY IT MANUALLY TO BE SURE IT DOESN'T BIND OR IS TOO HARD TO OPEN OR CLOSE.
IF ALL IS WELL CHECK THE SENSITIVITY SETTINGS ON THE BACK OR SIDE OF THE OPENER.
YOU WANT THIS SET AS LOW AS POSSIBLE AND STILL OPERATE THE DOOR WITHOUT REVERSING.
NOTE: THE FULL RANGE OF ADJUSTMENT IS ONLY ABOUT 3/4 TURN SO MAKE A VERY SLIGHT ADJUSTMENT AND THEN TRY IT AGAIN.
HOPE THIS HELPS
Feb 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
254 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
