Question about Tally Line Matrix T6100 Printer
Hammer settings for fonts in printed in proper manner in DP mode
How to use draft mode in epson lx_300+ii printe
Change the printer's default settings.
Hold down the Font button and switch the printer on. The printer will print language setting
instructions.
Press the font button again and the printer will print instructions for changing from default settings
Follow the instructions to change draft mode on/off.
Jun 08, 2011 | Epson LX-300+ II Matrix Printer
When we set the font it prints for about 2 pages , then returns to the 17 font. We need the 10 font to be able to read the huge amount of items printed. Any way to get it to stay on the 10 font?
You didn't mention which document type or from which program you are trying to print but the commands for the printer are normally embedded invisibly in the document and sent to the printer to accomplish font changes, punctuation, etc.
We might have a better answer and a suggestion if you comment back to this thread with the name/version of the program that produced the document.
Feb 21, 2011 | OKI MICROLINE 321 Turbo Matrix Printer
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Can not find a way to print in draft mode so toner
Laser printer can sometimes be set via the front panel on the printer for draft mode. Also, you might be able to set Draft Mode from the printer properties menu in the print driver.
The actual easiest way is change your font to something like Courier, 10P, which is a fixed spaced font.
When the document is finished, then you can do a "Ctrl A" and change the font to a more fancy font.
Don
Feb 18, 2010 | HP LaserJet 3600n Printer
Device Reboots when printing
Check jumper connection board for proper contact
Apr 08, 2009 | Panasonic WORKiO DP-C262 Printer
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
My HP laserjet 1300 printer Problems
You could be set in draft mode in your printers properties, or, you could be using ECONO Mode.
Sometimes People use PCL Fonts for their printers, and other use PS Fonts. PCL is the typical font type. PS is post script, which Adobe type fonts are used.
If you are set to PS Fonts using MS Word, you might try PCL Font types instead.
Jul 02, 2008 | HP LaserJet 1300 Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Font size
The font and size are determined by the print wheel. If you want a different font or size, you must change print wheels. It is very easy to do.... Open the top cover and pull back gently on the print hammer (sometimes has orange arrows) The print wheel is directl;y in front of the hammer and gently pull it straight up. When replacing the print wheel just remember to pull the hammer back slightly so the wheel can clear.
Sep 25, 2007 | Lexmark Wheelwriter 3500 Typewriter
Tally Line Matrix T6100 Printer Logo
19 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
