Question about Vtech Kidizoom Digital Camera
Powers on/off, but all other buttons won't work
With new batteries installed, the camera will only switch on & off. The screen is working, but all other buttons fail to work.
Any thoughts?
Exact same problem here. I called the Vtech and they will replace it.
Posted on Sep 23, 2009
Buy one from a store and keep the new one and send the old one back ;-)
Posted on Dec 27, 2009
Same as well but can't find receipt to return for replacement!!
Posted on Oct 25, 2009
My mini 10v Dell won't charge the battery, and if I take out my battery to just run on power it won't turn on. The light that lights on if power is on blinks for a sec or two and shuts back of
take the battery out and hold the power button for like 15 seconds. then put battery baCK on and plug it in but do not try to power on. lets saee what goes? remember not to power on
Jan 31, 2013 | Dell Inspiron Mini 10v Netbook Computer
New Bushnell Backtrack won't turn on.
I have the same problem with my Backtrack. I unlock back battery cover, unscrew some screws. Then I take the screen, check connection - it's ok. Then I try to close power switch with screwdriver. It started, but doesnt worked. There are some symbols on the screen. It's all I can do. My BackTrack still won't worked. For comments: greenspot@mail.ru
May 28, 2012 | Bushnell BackTrack Handheld GPS Receiver
Won't turn on
I had this same problem! Scoured the web and found no solution. This is what I did to fix it...
Remove battery. Unplug charger. Press and hold the power button for 20 - 30 seconds. While still holding the power button, re-insert the battery and/or plug in the charger. Voila! Came back to life and worked like nothing ever happened.
I also did the same thing with the record button, but it was the power button that got the result.
Hope this helps!
Feb 29, 2012 | Toshiba Camileo S30 HD Camcorder -...
My nikon coolpix 5700 will not turn on, i have bought new battery for it and it just won't turn on. what do i do?
Pleaseremove the Battery from the camera and give a look inside the batterycompartment. Use a spot light & make sure that place are clean , not rusted& the battery connector pin are not bend or broken. After that insert thefully charged battery and try to turn on. If its not turn on then its confirmthe camera internal power supply unit is faulty. For few reason this problemstarted.1. Theconnectivity cable from camera to Circuit board damaged or disconnected.OR2. Thepower supply transformer stop working & need to replacement.OR3. turnon button connection may disconnected.
After visual checking by the technician is possible to say which part isfaulty.
For the confirmation you need to visit a camera repair store. With outvisual survey technician can't confirm you which one of them is faulty. Thankyou.
Dec 04, 2011 | Nikon Coolpix 5700 Digital Camera
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Screen blinks for one second when switched to camera mode and than is black. Len's comes out but camera won't work. Card is installed and batteries are new.
screen blinks for one second when switched to camera mode and than is black. Len\'s comes out but camera won\'t work. Card is installed and batteries are new
Feb 20, 2011 | Fuji FinePix F420 Digital Camera
Flash doesnt work, flash icon keeps flashing, E:91:01 flashing
Hi
Try to reset your camera, heres one way of doing it
1. Turn OFF cam & Remove the battery or the power supply
2. Turn the switch to CAMERA for about 30 sec then & Turn the switch to OFF
3. Install the battery or power supply. & Turn the switch to MEMORY
4. Open the LCD cover and press the RESET button ( small inner button )
5. You will be prompt to adjust date/time.
6. Take some pictures and test out your flash
or open up the setup menu, and look for intilize or reset to factory defaults.
That should solve it, if it doesn't then its a hardware issue possibly the flash is bad some parts may need to be replaced to fix it. Take it to a local repairer or your dealer if your in warranty.
www.advancecamera.com will offer a free repair estimate if your outside of warranty.
Sep 10, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Vtech Kidizoom Digital Camera Logo
792 people viewed this question
Top Vtech Cameras Experts
ray gallant
Tom Chichester
Are you a Vtech Camera Expert? Answer questions, earn points and help others
