Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Same thing I can not even access gpedit in the run menu...it says its unrecognized and yes I typed in correctly.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
C:\windows\system32\gpedit.msc
Posted on Sep 06, 2009
My pen drive can't read by computer. I can't access into my pen drive at all but the pen drive light is keep lightning. Can I know what is the problem and how can I fix it? Thanks a lot.
>start>program>accessories>system tools>system restore >set earlier date. If you have the strong virus youcan not do that, then you should better to copy your data if necessary
follow step>set your hard disk in another computer .before install be ensurethat .another pc is well condition. >show hiddenfolder can see all system file >can open task manager>run type msconfig >enter, it will be open windows>run type gpedit.msc>enter ,it will be show.>run type regedit enter ,it will be open.think your another pc run in ok condition. Then type gpedit.mscand hit >administrative templates>system>turn off auto play>select enable>clickdown arrow >select all drives. Now auto run program off. you can see and delete easily all the hiddenunnecessary file .auto run file. From hare you can insert the pen drive and delete unnecessary file or format. Hope it will help you.
Dec 25, 2010 | Computers & Internet
Tip
How to increase your internet speed in a Windows pc by 20%
In this tip , we will talk about a simple way to speed-up internet easily.
With this tip your (daily) internet browsering will go a lot faster.
Because we all hate slow internet speed especially when it's not even hard to speed-up internet.
With this tip you will be able to speed-up internet up to 20 procent!
This because you now can use 80% and after speeding your internet up,
you will be able to use 100%.
And the best part is it only takes a few minutes to do.
This internet speed up tip works only with windows computers.
This is how to do it:
On a windows computer the operating system reserves 20 % of the bandwith to do things like
automatic updates. With some simple commands we are going to disable Limited reservable bandwidth and speed-up your internet!
Steps to speed-up internet:
First we are going to open the RUN command.
You can open the RUN by pressing: WINDOWS KEY + R
Then we will type gpedit.msc in run and ENTER.
If you can't upen RUN then search for
the application gpedit.msc in your computer.
After doing this there will pop up a window "Local Group Policy Editor"
When you are in this window look for: Local computer policy > Computer Configuration folder> Administrative Templates > Network.
You can now open QoS Packet Scheduler
When you have done this click on: Limited reservable bandwidth.
You are now in the menu where you can speed-up your internet.
To speed-up internet you have to do the following:
You will see the default setting as NOT CONFIGURED.
Click enable and drag the bandwidth percent to 0 and click then apply > ok.
The only thing you need to do is restart your computer and you will have speed-up internet by up to 20% !!
Yes it's really as simple as that. :D
on May 28, 2015 | Computers & Internet
Tip
How to boot windows xp fast!
Follow the following steps
1. Open notepad.exe, type "del c:\windows\prefetch\ntosboot-*.* /q" (without the quotes) & save as "ntosboot.bat" in c:\
2. From the Start menu, select "Run..." & type "gpedit.msc".
3. Double click "Windows Settings" under "Computer Configuration" and double click again on "Shutdown" in the right window.
4. In the new window, click "add", "Browse", locate your "ntosboot.bat" file & click "Open".
5. Click "OK", "Apply" & "OK" once again to exit.
6. From the Start menu, select "Run..." & type "devmgmt.msc".
7. Double click on "IDE ATA/ATAPI controllers"
8. Right click on "Primary IDE Channel" and select "Properties".
9. Select the "Advanced Settings" tab then on the device or 1 that doesn't have 'device type' greyed out select 'none' instead of 'autodetect
on Oct 09, 2010 | Computers & Internet
How to enable disabled registry editor
Start -> Run -> gpedit.msc -> User Configuration -> Administrative Templates -> System -> Prevent access to registry editing tools -> Right Click Properties -> Disabled
Jan 16, 2010 | Computers & Internet
Windows xp does not display the shutdown screen - I have to shut down via control+alt+delete I want it back?????
To resolve the issue, perform the following:
Click Start, Run.
Type gpedit.msc and click OK.
Navigate to the following path:
User Configuration\Administrative Templates\Start Menu and Taskbar
Double-click "Remove and Prevent Access to the Shut Down command"
Select "Not configured" or "Disabled"
Close Group Policy window.
Oct 30, 2009 | Microsoft Windows XP Professional for PC
My power button has been locked and I dont know how to unblock it?
1. type in gpedit.msc in the Run menu the go to user configurations then Admin Templates, then start menu and then disssable "Remove and prevent access to the shutdown command" log off and log on again
Aug 31, 2009 | Fujitsu Siemens Siemens Basic Line B17-1...
Windows XP Notification tray Bubbles/Notifications No longer show
Right click on the taskbar and look at properties. Uncheck "Hide inactive icons".
If already unchecked, try:
Start-Run type gpedit.msc and select ok.
In User config, open Start menu and Taskbar,
Double-click Turnoff Notification Cleanup in the right panel, select Enable and apply.
Good luck.
Close gpedit.msc and reboot.
Jun 13, 2009 | Microsoft Windows XP Home Edition
I am not work with my gpedit.msc
Unfortunately Windows XP Home edition does not have group policy editor and can not connect to a domain. You will need to upgrade to XP pro in order to have this functionality.
Jun 11, 2009 | Microsoft Windows XP Home Edition
I can not log off!! when i click on the start it does not have log off just shut down
If you can access the RUN Command type gpedit.msc and hit enter.
The Group Policy should appear and click the User Configuration, click Administrative Templates under that submenus, click Start Menu and Taskbar.
From your right pane, double click "Remove Log-off from the Start Menu" a dialog box properties should appear and click the "Disabled" radio button, click apply and click ok.
Your Log-off button should be appearing already.
Sep 10, 2008 | Computers & Internet
Task manager
If you are certain that you are logged on as administrator or has administrator privileges, then a virus is preventing your opening of the Task Manager. Additionally, the same virus is likewise preventing access to the Folder Option and the MSCONFIG function.
Of course the correct solution would be to run a full deep virus scan and delete detected ones. You can also try running RRT.exe to force access to the above functions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
51 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
