Question about Tomy I-SOBOT Robot
My Tomy I-SOBOT servo isn't working well, is there a way to fix?
My Tomy I-SOBOT is working fine, except one of the shoulder servos is making a clicking noise and it's very weak. The robot can't pick itself up anymore. Could I repair it?
  • altan86 May 11, 2010
    Hi, have you open the servo unit and inspected it?
Break pedal goes hard sometimes and won't start
It sounds as if you may have a leak on the servo, this will make the brakes go hard as the air leaks out. This can also make it hard to start as the mixture is affected by the extra air getting in. Without servo assistance on brakes the pedal will be hard. To test start the engine if you can with your foot on the brake, if it starts and the pedal does not go down, the servo is not working. Obviously you need the engine running for this, but you can also check the airline going to the servo for holes, normally this goes from the inlet manifold to the servo. This image shows the servo with the hose leading out, you can follow it to the manifold, make sure the engine is not hot before touching anything. typical brake servo connection on car engine Google Search
Apr 16, 2016 | Cars & Trucks
I just need schematic for Servo 200
Hi...try this...http://sportsbil.com/other/SAMSON%20SERVO%20170%20260%20550%20SCH.pdf thanks...hope it helps,
Jul 26, 2017 | Audio Players & Recorders
2000 explorer automatic transmission shifting fine but noticed fluid on ground and checked.fluid leaking from servo cover and clip half off.loks like servo cover sucked in a little where clip is off.
You don't need us
You know that you need a new
retaining spring/ring on the servo cover
Do not use it, as the servo won't work correctly
& you could break the band or wear the bore in the case
Sep 07, 2013 | 2003 Ford Escape
2007 gmc canyon sputters like it is going to cut off when applying brakes sometimes hard to start. just changed plugs and air filter . could it be brake booster or something else
if I say possible servo booster is faulty,surely you will feel it on the brake pedal ( stiff ),or the engine running would be erratic.the other alternative situation is the pipe( hose ) which is connected with inlet manifold and servo booster and inside has the check valve probably is faulty. Test : off engine,pump brake pedal several times till gets stiff. Keeping your foot on brake pedal start the engine and if your servo works fine then the pedal goes a bit down,if not will not move at all. If the engine is running erraticly then with engine off, remove the pipe connecting manifold and servo block the pipe you remove from servo side,block it and start the engine,If engine run fine,then you must confirm whether is the servo or the check valve hose. For the check valve hose how to check,just put in your mouth the servo side pipe and blow into,if the air goes in the engine means that the check valve is broken and you must renew the pipe with check valve,if on blowing into will not allow air to get through,means is ok and the servo is the fault. Good luck.
Jan 03, 2013 | 2007 GMC Canyon Crew
Why does my Tomy fall on his face whenever he attempts a bowing motion?? Any time he tries to bend forward he seems to lose his balance and falls face down!
Hello and good day to you!!!
Maybe your Tomy had a heavy face did you try to look the connection of it if it has a loose parts???
If it has a screw between heads please tighten it and test again if there is any improvement...
Note:Please do not pay me if your problem did not solve by me...
Thank you and please do not forget to rate me and have comment if you have more questions...I am happy to serve you..
Jul 04, 2011 | Tomy I-SOBOT Robot
My grandchildren stepped on the i-sobot and broke the foot off is there anyone who can repair this
Hello apan..... you may be able to repair it yourself using some epoxy adhesive. this is a very strong bond. you can get it at any home depot, lowes or other hardware store. It comes in several drying time categories such as one minute, 5 minute, 60 minute.
If possible it is always a good idea to clamp it as it dries. Joe
Feb 10, 2011 | Tomy I-SOBOT Robot
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
Sep 25, 2009 | Traxxas Rc Revo Nitro Monster Truck
I lost my i sobot manual is there any way that i can get another?
Visit this site to get the manual, warranty, and the supplementary alignment sheet
http://www.isobotrobot.com/eng/more/download.html
Jul 04, 2009 | Tomy I-SOBOT Robot
Tomy I-SOBOT Robot Logo
268 people viewed this question
Top Tomy Toys Experts
Jennifer Rock
Jennifer Rock
Colin Stickland
Colin Stickland
ray gallant
Are you a Tomy Toy Expert? Answer questions, earn points and help others
