Question about Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera
Got the dmc-ts1 couple of weeks ago, can't read SDHC cards
The camera reads my regular 2gb sd cards fine but gives me the same ''Memory card error'' when a freshly formatted (FAT32) 16gb sdhc card is inserted. I'm trying to reformat with another program (again), but I'd appreciate any advice!
Thanks
  • kimbago3 Sep 07, 2009
    Because of the error, I can't even get to the format menu on the camera, so I can't format it in there. Thanks for the reply so!
    Brigadier General:
  • 11,967 Answers
The card needs to be formatted in the camera to work properly.
Posted on Sep 07, 2009
My lg does not read 2gb sd card.it tell me to insert a new one.Bt it can read 128 mb sd card
Your 2 Gb is not just an SD card, it is a SDHC card. The first 2Gb SD cards, still were SD, but 2Gb was the limit for the FAT 16 and 32 format and for the normal SD cards. The same happened with the hard disks. They developed the SDHC card, and made the new hardware downward compatible with the old SD cards. So in a new camera, you can insert SDXC, SDHC, SD and even MMC cards. But the cameras, card readers and phones, who were made for SD, can't use the SDHC or SDXC cards.
SDHC can work with memories up to 32 Gb and from that on, it is SDXC.
There still should be some 2Gb SD cards around, but not sure you still can fine one. The producers of memory cards now only make SDHC cards and up. Perhaps you only can get some 1Gb cards as SD card, but perhaps nobody will ever make these cards anymore.
I mannaged to buy a 4 GB SD card a few years ago, but that was the last I ever saw in the capacity. 25264488-uil2tdgcy05knvgzh4oup5lj-2-0.png
Nov 01, 2014 | Cameras
Can a panasonic dmc-fx8 use a sdhc memory card
This camera cannot be upgraded to read SDHC cards. The maximum is 2Gb Secure Digital.
Sep 18, 2014 | Panasonic Lumix DMC-FX8 Digital Camera
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
I have tried a new sd card for more memory and it reads card error with every new card i try i've tried 3 different cards now and the original still works so i know the reader works but it just doesnt...
You won't be able to use a card larger than about 1GB (maybe 2GB) in this camera. "SD" cards larger than 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 29, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
I purchased a sdhc 4gb memory card for my Panasonic DMC-LZ2 Camara and when I put it in I get a message that says memory card error. Do I need to format it? and how do I do that
The DMC-LZ2 uses SD and MMC cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible. You will need to use SD cards 2GB and smaller.
Dec 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Why can't I get pictures off of an 8gb but I can off of a 2gb chip?
Some cameras cant manage/format large size memory cards as they where not made to handle that size. Check your user manual which should tell you the maximum size memory card your camera will take.
Aug 04, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
Using a sdhc card in a Panasonic DMC-FZ10
There is no "new" firmware upgrade for this model. Meaning it is NOT compatible with the SDHC card. Largest you can get is an SD 2GB card.
Sorry
Dec 18, 2008 | Panasonic Lumix DMC-FZ10 Digital Camera
Panasonic fz 18
Sorry for the extreme delay in answering your question: I've been trawling for old unanswered questions today and yours came up. The following answer will undoubtedly be way too late to be of use to you, but may assist others searching FixYa for an answer to the same problem.
You have been mistaking SD cards for SDHC cards. They look the same but are different, and your camera cannot use SDHC cards as it was designed before they existed. The limitation is due to the hardware in your camera so it cannot be updated to SDHC standards.
Your 2GB card was definitely an SD card as SDHC cards have a minimum capacity of 4GB, and 2GB SD cards are the maximum capacity which your camera can handle. Your only fix is to either stick to 2GB maximum capacity SD cards or to replace the camera with one which is SDHC compatible.
Aug 25, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Panasonic Lumix DMC-TS1 / DMC-FT1 Digital Camera Logo
372 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
