Question about Garden
Murray 4.5 hp Q lawn mower runs rough and smokes.
Murray 4.5 hp Q lawn mower runs rough and puts out some white smoke. But, about 2 minutes before running out of gas the motor smooths out and runs great. How do I adjust the carb?
  • 68 Answers
White smoke indicates that it is burning oil. The smoke would be black if it was running rich. So probably the rings will need to be replaced eventually. These mowers are prone to problems but the carbie is least likely to be the problem. So before you adjust the carbie take the cover off the top and give it a good clean and check that all the hoses are connected and are not cracked. Then make sure the airfilter is clean, blow it out with an air compessor or better still get a new one. Then try it out agian. If this doesn't help there is two screws on the carby marked L and H. Turn these only 1/8th of a turn at a time and note or make their current position. Start with the H scew with the mower at full revs. Turn anti clockwise untill you get max revs then turn it back a bit. Running too lean will over heat the motor and damage it. Then if needed adjust the L (or Low)screw. If you get black or grey smoke when you push the throttle up from idle to full its too rich so turn clockwise. If if slows before it picks up to full revs turn anti clockwise.
Posted on Sep 06, 2009
My Bolens 500 Series lawn mower is hard to start
if it is a pull motor then you have to put some oil in the end of the chain(string) near the motor then it will pull smoothly.
Sep 29, 2012 | OEM Replacement Parts Garden
Helping a Friend
the damage may already be done white/blue is oil smoke i would start it up and let it run it may just be oil in the muffler if not your not going to cause any more damage then what is already done
Apr 21, 2012 | Murray Garden
I have no rpm's mower only runs slow. plugs foul with black carbon after 30 minutes. This is a murray 6.5 hp brigs any solutions
CARB NEEDS TO BE REBUILT. FLOAT IS STUCK.. AND CHANGE OIL AFTER REPAIR OIL WILL HAVE GAS IN IT AND IT WILL JUNK THE MOTOR IN NO TIME ... VOTE !
May 20, 2010 | Briggs & Stratton Garden
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Lawn mower does not run.
Needs a new diaphragm. Its between the carb. and gas tank. It collapsed and doesn't allow enough gas to carb. to keep motor running.
Apr 10, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower running rough
adjust the carby. also u might want to replace the diaphragm in the carby. might work wonders
Mar 31, 2010 | Mtd LAWN MOWER PART # 791-180705 Assembly,...
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Lawn mower engine runs rough and puts out white smoke
Pull the carburetor and clean it for staters.Be sure to change oil any little bit of moisture in the crankcase will let it smoke white by seeping by the valves and piston rings.Also put a little small amount of dry gas in the gas tank to rid all of the water that may have been left in the tank. I some of this will help you.
Mar 18, 2009 | Garden
Garden Logo
2,066 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
