Question about Sony Grand WEGA KDP-57WS550 57" Rear Projection HDTV-Ready Television
The picture of this tv is off. when I try to do the flash focus, the vertical position is right but the horizontal position is off. in the convergence, the green is ok, the horizontal line is tilting up on both side for the upper portion, and the line is tilting down for the lower portion . the problem appear to the red and blue color. because of the problem, I tried to replace bothof the convergence IC. the pictue looks the same as before the replacement.
  • gemmychen Sep 06, 2009
    I cant find the convergence board (Ds mount)at www.partstore.com. it is no longer available.
    is it possible the Ad mount has some problem too.
    and, when i buy the Ds mount board , does it include the convergence IC?
  • 3,230 Answers
Well you can order your part from the below link -
http://www.sony.net/SonyInfo/SupportAll/
Good Luck!!
Posted on Sep 06, 2009
  • 3,741 Answers
Most probably replacing the convergence STKIC should solve this problems.but in some cases the capacitors on the convergence also go bad.the capacitors which go bad looks buldged up from its top or have burned marks on their side or they look bit loose from the board.but if all the capacitors look perfect and convergence ic is soldered properly .then in some cases the convergence board it self gets faulty this is very rare but in some cases it has been seen that convergence board circuit gets short internally and convergence board is dead completely.so the board needs replacement.so check out the convergence ic which you have connected are they properly connected and with proper position and next check the capacitors on the board.if all ok the convergence board is faulty.----- TO replace the board whole signal/convergence board cost for about $360.00 plus shipping .you can get it at ------- www.partstore.com ----- Here are instructions for removing this board wether you want to replace it or want to know how to get it out to replace the STK ICs.
First get the back cover off the tv (6 hex screws) now we will lift part of the chassis out so you aren't putting your screwdriver near the tube driver boards for safetys sake. You will notice there is a plastic frame screwed to the wood frame of the tv. There are 3 wood screws along the back bottom edge of the TV securing a plastic frame down loosen them. Now GENTLY pull the plastic frame which the boards are screwed on back and angle it out to the right the HV wires have plenty of slack for you to remove the signal board. If wires from the signal board are obstructing try pulling them out of their cable clamps to give you more slack.
You don't need to discharge the RED (high voltage wires) from the flyback and its relatively safe to work around them just don't go poking Mr. Screwdriver on them. Or touch any area of the biege power board the signal board is the green one on the right of the tv looking from the back. To disconnect the power from the signal board to the power board get a flat head screwdriver and you'll notice 3 connectors from the signal board to the power board and on the power board side you will see small flaps protruding from the connectors GENTLY pry them up with the screwdriver. Pull out all the connectors from the board if you wish take pictures of them or draw a diagram while they only plug in one place its pretty time consuming if you forget where they go.
Now loosen the screws from the board to the plastic frame and the support for AV board at the back (4 screws) then remove the little screws visible near the A/V Phono connectors once all of them are out pull the little plastic bezel off. Now if you wish pull up on the A/V board and it disconnect from the signal board. Now for removing the board itself don't pull straight up on the board or you'll break it pull it up from the power board side first then slide it to the left and pull it out. If the board doesn't come up check for screws DON'T FORCE or you may crack the board.
Replacing the board is very straight forward the connectors will only connect in one place so you can't screw them up. Also there were 2 vacant connections where no cables connected one on the metal shielded tuner board and another on the signal board. The only thing you have to watch is the 3 plugs for the tubes my cables were marked from the factory the red connector had a red line on it same for the blue and the green had no mark because its the remaining cable. Just match them up to the printed Red, Green, and Blue on the board and you can't go wrong . But if you do all that will happen is your TV colors will be all funky.so connect it at the excy position. this will help. ---- thanks.please do rate the solution.thank you for using fixya.keep updated.
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
Red out of focus
Hi. your convergence board is failing. this board regulates the the alignment procedure and , the chip set is damaged. replace the convergence board soon.
May 22, 2009 | Toshiba 42H81 42" Rear Projection...
At turn on picture will not focus
if your tv is an older type picture tube projection.Its possible tv needs a new focus block.This can only be changed at a repair facilty.Check our repair directory for repair assistance in your area
Mar 18, 2009 | Televison & Video
No picture on magnavox 32MT6015D
THAT THIN WHITE LINE IS YOUR HORIZONTAL LINE MEANING YOU ONLY HAVE THAT. THE GOO NEWS IS YOU HAVE HIGH VOLTAGE MEANING YOU ONLY NEED VERTICAL TO FIX IT.. I WOULD REPLACE THE VERTICAL TRANSISTOR OR CHECK FOR ANY BURNED RESISTORS ON THE VERTICAL SIDE
Feb 22, 2009 | Philips Magnavox 32MT6015D TV
Vertical rolling of picture
psess the volume  up and down button together on the front pannel of the tv and then shut off the tv and it will stop scrolling.
Jan 05, 2009 | Akai LCT3201TD 32 in. LCD Television
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Screen position needs adjustment
try opening up the back and the chip with the thousands of mirrors can be adjusted and the should be 4 screws holding it in place but then you could also be pplaying with the focus as well i'd recommend it being a two person job
Oct 02, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Picture broken and shrinking
You need to change your vertical IC, along with some capacitors around the vertical IC. Capacitor with value 220UF, 10uf, 470uf and finally 1000uf. Doing this will fix the set. Total cost under $40
Best regards
Circuitcity
Nov 29, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Picture has a horizontal row
this symptom is caused by a trouble in the integrated circuit of in the vertical oscillator circuit. try to look if your tv has a vertical hold control at the back or inside, if it does not have, u have a problem in the vertical oscillator circuit. by the way, its not the horizontal that u should concentrate into, its the vertical. coz this is a vertical sync problem.
Jan 12, 2007 | Konka K2001UM TV
Sony Grand WEGA KDP-57WS550 57" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
