Question about Philips Magnavox 9P6034C 60" Rear Projection Television
IC Chip? At first the picture is small...then it gets large...the small again...for about 5 minutes and then it was fine. (kind of like it needed to warm up or something. Now, there is no picture or sound at all. Phillips Mag. 9p6040c104 model number
  • Philips Master
  • 3,459 Answers
Its a common problem with this model. Goto www.TvRepairKits.com to get the parts and instructions to fix the TV.
Posted on Sep 06, 2009
I have blue shadowing around the picture...what does this mean?
In the customer menu if you select CONVERGENCE is the blue off and will not adjust?
IF this is the case the WS-55859 uses a single Convergence IC that needs to be replaced---this model uses a STK-393-110 CHIP---it can be purchased on Ebay for about 12 dollars plus shipping.
Most of the time if this is the problem---the chip and any of the blue protect resistors around it that are bad need to be replaced.
Clearly, I do not know if you have the skill to do this repair---I have start to finish instructions for this kind of repair--tells you what you will need to do it and the only question is can you do it yourself?
Most shops get 300-400 for this kind of repair--if you can do it yourself you can save a lot of money---once the set is fixed it will not have the same problem again for 5-8 years (life span on the chip).
LET ME KNOW IF YOU HAVE ANY QUESTIONS OR WANT THE INSTRUCTIONS- I have repaired hundreds of these sets with this kind of problem----I am here to help people.
Regards, SD TECH
Oct 13, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Sony KP-57WS510 57 inch rear projection - Rainbow colors and arch
hi, you`ve lost your convergence ic`s, unless your very proficient at solder work I`d advise you call a tech, will require removing 2 large IC`s and possibly a few small support parts, resistors, chemical fuses etc. Every place is a little different but runs approx. 300.00 at my shop, gl, video-tek
Jun 04, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Phillips 52'' projection tv.Picture goes small then large then off
Your original problem was/is an "opto" IC (chip),which causes the power supply to regulate low when it fails. It is a 6 or 8 pin chip. Sounds as if maybe more has failed now. Switch mode power supplies are not for the faint of heart,or DIY. I recommend having it troubleshot by a tech.
May 31, 2009 | Philips 50PP9202 50" Rear Projection...
50' Philips tv issues
If you power up/down a bunch of times in a row (10-20 times)
Do you see a bright flash before it shuts down?
If so my guess is a faulty resistor and not the chip I mentioned earlier. I have seen a few posts on this site in regards to faulty resistors on the CRT board(s). If they go bad the set will shut down so that it does not damage the CRT.
Aug 20, 2008 | Philips 50P8341 50" Rear Projection...
Problems after new ic chip install
Did you check for open resistors in the convergence circuits? Often that is what happens when the old ICs wear out it will cause a couple resistors to burn open, and they show no outward sign of being bad. Also double check the IC pins connections for solder bridges thats another common problem, I always use a magnifying glass to double check my solder when ever I do convergence or any IC work where the pins are close. But with the streaks youre describing I would think maybe resistors.
Jun 16, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Convengence problem?
the stk ic . the big amp chip has cold solder joints . resolder the ic
Nov 30, 2007 | Mitsubishi WS-55857 55" Rear Projection...
Degrading picture with my Dwin projector
the colorwheel is going bad and needs replacing. the colorwheel needs to spin fast enough to sync up with the dmd chip. if it cannot, the pic goes bad then off. the flashing is the colorwheel trying to catch up.
Jul 05, 2007 | Dwin TransVision 3 Plus Multimedia...
Sony Trinitron kv32fs16 picture shrinks
You have a bad solder connection in the vertical circuit. This will require you to resolder these bad connections before it blows out the vertical output IC or other parts in the circuit. Do this ASAP before you make a small repair into a large one. If you have no solid state printed circuit board experience, please play it safe and take the set into a pro to do this for you. Good Luck
Jun 28, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
KV-32S45 Disappearing Picture, Good Sound
yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Apr 19, 2007 | Sony KV-32S45 32" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
