Question about Kenmore Refrigerators
DEEP SCRATCH ON DOOR OF KENMORE REFRIGERATOR WITH ULTRA SATIN FIN
CANNOT BELIEVE THERE IS NOT ANY REPAIR FOR ULTRA SATIN FINISH. DO I HAVE TO REPLACE ENTIRE DOOR?
3 Suggested Answers
  • 363 Answers
SOURCE: is there any way to fix scratches on the door of
go to appliancefactoryparts.com, they may have satin touchup paint, or go to an appliance store
Posted on Jul 30, 2009
  • 1456 Answers
SOURCE: I have a BLACK
Hello
You will be needing a scratch be gone kit.
Assess the damage. Determine if this is a deep scratch or a surface scratch, by running your finger across it. If you can actually feel the indentation, you have a deep scratch, gouge or ding. With clamps, carefully hold a small piece of dry ice over the gouged area. Hopefully,it will pop out, and not be as noticeable. Then you can treat it in the same way other scratched areas are treated in the steps below.
Use an abrasive pad from the Scratch-B-Gone kit to repair scuffs, light scratches and even deep scratches. The kit has 4 different abrasive pads and instructions to tell you which one to use depending on the severity of the scratches and scuffs. Otherwise, go to an automotive shop and buy different fine grades of sandpaper.
Apply a small amount of Ultra Shine from the Scratch-B-Gone kit onto the appropriate abrasive pad. Or use an automotive rubbing compound on the sandpaper.
Begin rubbing the damaged area of the satin in the direction of the grain covering over about a 5-inch area at a time. Slide the pad backward and forward increasing pressure as needed until you see the scratch is disappearing.
Repeat this process until the scratch is removed and the surface is restored. For a deeper scratch, dry rub the area with the coarse pad, and wipe area off with a microfiber cloth to make sure the scratch is gone.
Blend the metal surfaces by using the finest grade sandpaper or abrasive pad with the rubbing compound or Ultra Shine and gradually increase the area around the original damage to about three times the original scratched area. Be sure to go with the existing grain of the material so you don't create crosshatching.
Posted on Sep 30, 2010
The outer skin on the freezer door is scratched. Is there an inexpensive fix to replace the outer skin on model 10651123210
If the scratch is on the smaller side and not a deep gouge, you should be able to obtain touch-up paint for the appliance. These products are usually available at Sears appliance parts depots or more generically at home improvement stores.
Jul 16, 2015 | Kenmore Refrigerators
Tip
How to Remove scratches outside refrigerator door
This tip is only for small scratches which are like hair sized one not more than that,If you have deeply scratched panels,you have to hire a professional to refinish them.
Today most of the refrigerator door come in stainless steel based plastic door.You can easily remove the small scratches on these door.
Steps to be followed:
1)Take white cloth and it should be a soft and dry one.
2)Buy stainless steel polish and squirt it on a small cloth and rub over the scratched area.So that it will get pasted over it.
3)Rub in one angle and in same direction.
4)Now rub the scratch with scouring pad over the surface of the polished scratch.
5)Buff with a clean cloth and remove the small particles so that it wont make more scratches.
6)Wait for 3 hours and take some water dipped cloth and wipe on it.
7)For deep scratch you have Teflon coating so that no more scratches will occur and also removes the deep scratches.
on Sep 01, 2010 | Refrigerators
Knob does not come out all the way into the door frame for closure. why?
Most common reason for this is the hole its going into on the frame is either not deep enough and/or the hole and strike plate/larch are not properly aligned (i.e. its hitting the side of the wood etc.,).
Mar 01, 2015 | Ultra Satin Chrome Exterior Entrance Key...
My stainless steel finished side by side refig. was scratched during our construction...I've tried auto rubbing cmpd. to no avail. Any suggestions?
Depending on how deep the scratch is, theres a product called "Scratch-be-gone"....should do the trick if its not too deep.
Feb 28, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My son used a magnet on the black door and made a several scratches
If the scratches aren't deep, you can try auto POLISH to remove them. NOT rubbing compound. If they are deep, you can hide them with car wax.
Nov 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Scratch on the front panel, how do we repair. Does it have to be replaced?
Scratches aren't an easy or inexpensive fix. However, if, like most appliances, your's has a protective clear coat on it, you can try using a small applicator (like a Q-tip swab, etc.) and a very, very light amount of clear lacquer and lightly dab it onto the scratch and quickly wipe off the excess with a clean, lint free, cloth.
You can buy a can of clear aerosol lacquer that closely matches the type of finish on the fidge panels, (matte, satin, gloss).
The trick is to NOT spray directly onto the panels, but rather spray a small amount into the cap of the aerosol and using the swap, dip it into the liquid and, again, dab it lightly onto the scratch.
Another option is to purchase one of those automotive scratch repair kits that you see advertised on TV or in auto parts stores and follow the directions for fixing the scratch.
If you take your time and go lightly and carefully with the application, you can get a pretty decent repair that will make the scratch all but disappear. If it's also dented, then you've got another issue to deal with, but in any event, attempting a repair of the scratch will cost you hundreds of dollars less than buying a replacement door panel.
I hope you find this Very Helpful and best regards!
Oct 14, 2009 | KitchenAid KSSC36FMS Side by Side...
Scratches on door with stainless satin finish. Is there any way t
the only way is to buff it with a graining wheel on a buffer try sheet metal guy
Jul 27, 2009 | Refrigerators
Is there any way to fix scratches on the door of the refrigerator. We have a ultra satin finish.
Jul 26, 2009 | Refrigerators
Scratched stainless steel
Hi Try www,finishing.com/4000-4199/4148.html I do not know if this will be helpfull, but give it a go
Nov 02, 2008 | Kenmore 55683 Stainless Steel Side by Side...
Repair scratches on black door front
Mr....other than repainting, the only suggestion I have is one of those scratch repair kits that they sell at Pep Boys. The finish materials...paints...not stainless...are about the same as used on cars. Use a soft lambswool bonnet buffer and go slow.
If it is stainless...use 00 steel wool in a one directional sweep with a little bit of light oil.
good luck, sir.
Dec 03, 2007 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
222 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
