Question about Plumbing
Taco timers and Surge Protectors
I installed an eternal water heater and a TACO timer recirc pump and first they were plug into the same outlet. The taco seemed to cause a surge and it shut off the eternal. I moved them to separate outlets and put a surge protector on each. One plug belkin. The surge protector on the taco is blown. Is it my wiring, my TACO or my surge protector.
Thanks
  • 832 Answers
Do they run at the same time? The two items consume
a lot of power. Check the voltage when they are turned on. If the voltage is below 90 Volts. The power surge at your Taco is great. Then, the surge protector could not
handle the current inrush that's why it's blown off. You
must install a surge protector that can handle the Taco
current inrush.
Posted on Oct 31, 2009
Testimonial: "Thanks so much. I will check the voltage."
  • rolando ingking Nov 01, 2009
    Ok, Great. Hope that this will solve your problem
Taco Pump always on
Hello Melville,
That is a VERY NICE FEATURE designed to
give you INSTANT HOT WATER every-time
you use the faucet...
If it is done well it DOES NOT sound like the water
is running all the time... (big if).
The really wonderful part... HERE in CALIFORNIA
where WE have INFRASTRUCTURE to support
15 MILLION ... and we approximate 40 MILLION thirsty
residents... It is NICE to know A FEW responsible people
like you ARE NOT WASTING Gallons of water at EACH USAGE...
waiting for the water to get warm.
You ALREADY have instant warm water at your finger-tips because of your circulating pump.
On internet
https://www.bing.com/search?q=taco+1%2F2%22+006+bc4-tac&form=EDGEAR&qs=PF&cvid=dc68132e9d6a4f30a8cda2c9fd0f3617&pq=taco+1%2F2%22+006+bc4-tac&cc=US&setlang=en-US&PC=DCTE
Amazon com taco 006
Best price: 3/4 inch TACO
Taco 006 B4 Bronze Circulator Pump 3 4 Inch Sweat Portable Power Water...
Carnac the Magnificent
Mar 30, 2017 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Where is the on switch, for constant hot water located?
Question posted under Taco digi timer control
http://waterheatertimer.org/images/Digi-dial-image.jpg
http://waterheatertimer.org/images/Taco-265-3-timer-600.jpg
Taco must have stock of old digi timers because that timer is discontinued.
It's a good timer. It's just been replaced by less attractive, more complicated digital timer with fewer buttons.
The manual switch for this timer is located at top and is denoted by 'hand' symbol.
Press left side for ON and right side for OFF.
Aug 23, 2011 | Taco 265-3 Digital 7 Day Programmable...
First My sister inlaw has a 3/4 recirc line. used the by pass h&c under last faucet to use cold as recircu line. Note acutal 3/4recirc is in kitchen but even thou closer to water htr. it is last for...
I don't understand everything being asked, so add a comment any time.
Problem1 is excessive electric bill.
Suspect is new 120Volt Taco recirculation pump.
Look at motor nameplate for amps and watts and HP. Taco pump is usually robust 1/3 HP which is 252 watts or same as running four 60 watt light bulbs.
If pump runs 18 hours per day x 252 watts = 4536 watts or 4.5 Kilowatts per day
Buy a kill-o-watt meter that plugs into outlet, and plug Taco pump into the meter for 48 hours.
This will give you total watts used for that time period.
1000 watts = 1 kilowatt.
Electric bill is probably 12 to 20 cents per kilowatt.
So if Taco uses 4.5 kilowatts per day, that is $.54 to $.90 per day multiplied by 30 days.
So cost is $15 to $30 per month.
Problem2 is Taco runs too long.
Taco operates either by thermostat or by timer. You choose which mode by using slide switch that is usually located under the timer dial. Set switch to TIMER to use timer, and ON to use thermostat, and off to turn TACO off.
If Taco is set for thermostatic operation, the Taco might be defective. Or there could be crossover problem at single handled faucet.
Another problem could be air in the water line: install air vent.
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Water-heater-recirculation-system.html
http://waterheatertimer.org/How-to-set-timers.html
Jul 17, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Have a taco 24 hr timer on water heater of home we purchased. pls descvribe how to set it to circulate the water just twice a day for a couple of hrs. thx, mg
Your question is very big because recirculation systems have a lot of parts and options.
Please open following link for re-circulation system resources that show pictures of how the system works. After reading information, add a comment with more questions.
The page shows two different types of Taco timers. One timer is programmable and the other timer is called analog timer where the timer dial rotates just like a clock. Small pins located on dial face are set inward or outward. As the dial rotates, the pins move a tiny on-off lever that turns the pump on-off. The pump can also be set to operate thermostatically. You choose either timed operation or thermostatic operation using slide-switch located under timer dial.
Look at, and read information on link above. Try some things on your timer so you are familiar. And then add a comment with specific description of your Taco timer, and include what you have done so far.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 11, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
My Taco Time Clock 265 Analog is not working. I overloaded the circuits last week and the GFI outlet 'died'. I have replaced that outlet, but the time clock is not operating. Help, I long for immediate hot...
Yes it should be easy to replace.
The manual appears on following link:
http://www.taco-hvac.com/uploads/FileLibrary/102-067A.pdf
'Analog' timer has dial face that rotates as time passes, the 'digital' timer has programming buttons.
The manual seems very straightforward.
Turn power off, connect wires, set timer.
Of course what seems simple to experts who do wiring each day, may not seem simple to person asking question. So add a comment with specific detailed question if you need help.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 02, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
I have taco 671-2 aquastiat and water going out from there what i can do
Going out from what?
Is the Taco pump leaking?
Or pipe connected to taco?
Or is the water heater leaking?
1) If this is emergency, turn off water and call plumber.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) If water heater is leaking:
http://waterheatertimer.org/Water-heater-leaking.html
3) If pump is leaking, then pump needs to be replaced.
4) If pipe going into pump is leaking, then it needs to be taken apart and fixed.
5) Add a photo to this post so I can see problem.
After that, I can give best direction to go.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
For a price, expert works with you via e-mail while you work on Taco or any do-it-yourself project.
Feb 19, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
My Taco 006 circulation pump quit working. It make a vibrating noise and does not pump. I just bought it a year ago. Can you help.?
Usually when these motors slow down, they get hot and burn out.
You can try taking it off and cleaning with CLR, but normally when they stop working, they do not revive.
I am not sure what the warranty policy is from Taco, or if Taco has a parts list.
I think following link takes you to the Taco website:
You can contact them for warranty/parts information
http://www.taco-hvac.com/en/products/Hot-Link%AE%20Domestic%20Hot%20Water%20Recirculation%20System/products.html?current_category=398
Link below has information on recirculation systems with links to manuals and competitive products
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on pump/timer or any do-it-yourself project.
Jan 10, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
I bought a new house and the water heater has a circulating pump with a Taco 265 timer. No instruction manual so I can't figure out how to set the timer. You wouldn't happen to have a little instruction...
Maim website:
Main website Search for Taco 265-1 gives link to manuals:
http://www.taco-hvac.com/search.html?gsearch=Taco-265-1&action=results&cb_products=YES&cb_filelibrary=YES&cb_news=YES&search_type=all_terms
Direct link to pdf manual:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.taco-hvac.com/uploads/FileLibrary/102-067.pdf
Instructions show series of actions to set digital program
Press h key ...
Press m key...
Press Day key...
Press Prog. key to enter...
Sep 10, 2010 | Taco 265-1 / 563-2 Combination Analog 24...
Plumbing Logo
148 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
