Question about HP Officejet Pro L7680 All-In-One Printer
Scan doesn't work
This is new equipment. The scanning has never worked. When I start up the laptop, it says something like "the scanner won't work - turn off the printer and turn it back on to get it to work" (something like that). What's wrong?
I have a hp F4272 all in one ,when i used the scanner hp cue scanning flow component has stop working,any one who has an idea of this problem?
Posted on Sep 06, 2009
SOURCE: Scanning error - cannot scan error code 2,155,0 ???
I had the same problem with a new Canon MP970. Printed ok, but couldn't communicate with the scanner - error 2,155,0.
Canon phone support didn't help, and suggested it was a firewall problem. I uninstalled, and re-installed, turning off firewall, virus software, and everything. No luck. Tried several USB cables, no luck.
Then I uninstalled again - as well as a couple of old drivers and software associated with two now deceased printer/scanners.
This time I plugged the (same) USB in and turned on the device, using Windows' own hardware install wizard.
Now it works fine (at least for now... touch wood).
So - the problem might be either conflict with other printer/scanner devices installed, or with Canon's installation software.
Posted on Aug 02, 2008
rakeshpramod
  • 234 Answers
SOURCE: scanner
Are you getting a NO SCAN OPTION
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
If the software is not installed then you will have to install the printer driver and software sucessfully first.
Good Luck
Posted on Oct 20, 2008
chessmaster2
  • 160 Answers
SOURCE: I dont know how to scan with my multi purpose printer
are you using any kind of program to edit photos, etc? if so, you can use it to scan from the printer very easily. open the editor, select import file, twain source, scanner flatbed. the save the file using an appropriate format, jpeg, doc etc. you can then print the file normally.
to get a manual for your printer, goto the epson website, select the proper printer and download the online version of the manual.
Posted on Nov 26, 2008
  • 2692 Answers
SOURCE: how do you use the scanner?
Link to operations Manual :
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us〈=en&product=90792&
Posted on Mar 11, 2009
madguy1089
  • 21 Answers
SOURCE: i have a lexmark x3350 and the scanner wont scan
Alot of the X3350 all in ones have there scanners go bad if you still have a warranty for this printer then call Lexmark if not then you can go out and buy one for like $85.
Posted on Apr 28, 2009
Can I scan picture and send it to my laptop with out the cable, can't find it anywhere if so can I get a new one somewhere?
you have to be t the printer scanner to scan and send it (SAVE) to your laptop , it will be in documents under whatever name you gave it
Apr 24, 2018 | The Office Equipment & Supplies
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
I have a Lexmark x7170 3 in 1. I got a new-ish laptop with Vista and now my scanner doesn't work. I've tried download drivers, but nothing seems to work. Are the compatible at all?
In this case Try to Do a Wia scan i will tell u how..........
Windows Vista: Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............
If it doesnt scan and does the same thing it insists that there should be a Problem with the scanner.........
If that works..........
Software Problem.............
Uninstall and Reinstall the software................
Good Luck..................
Sep 24, 2011 | Lexmark X7170 All-In-One InkJet Printer
Im trying to scan a document but its saying error code 2106. i have it hooked up through wireless
Try these things:
1. place a doc to scan in the scanner. Close the lid and hit MENU, COPY document, START.
If that doesn't work you'll need to contact kodak. If it does then try this next:
2. Check for ADMINISTRATOR rights.
  1. RIGHT CLICK on the kodak icon and select Properties > Compatibility tab > Run this program as an administrator
  2. Select RUN AS ADMINISTRATOR
  3. click APPLY
  4. click OK
Then try scanning again. If it still doesn't work then-
Reload the driver:
  1. select Start > Run.
  2. Type %windir%, then click OK.
  3. Double-click twain_32.
  4. Right-click Kodak, then select Delete.
  5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to (cd drive: > printer > scanner.
    Double-click aioscannr.msi, then follow the instructions to remove it
  6. Then go to cd drive: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
  7. Open Home Center Software
  8. Select Scan Documents and Pictures.
  9. Scan a document
If it still doesn't work then you'll need to take it in for service.
Jun 15, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have a cannon printer that I always could scan with my old computer. I have a new laptop and I don't know how to make it scan now.
Yeah, something changed and some older scanners do not work with new OS and hardware. Fortunately new printer/scanners are not very expensive. I think the programming standards changed in terms of scanners. One cool option of new stuff is wireless printing and scanning, so this means that you no longer have to go to the host (sharing ) system to scan, but you can scan and control from the laptop. I prefer HP. Set up works fairly easily, but you do need to have access codes for your router. FOLLOW install directions EXACTLY, and specifically NOT plug an play.
Oct 03, 2010 | Office Equipment & Supplies
Most of the time my Nikon 5000 works well. Recently I encounter the following problem. After several normal scans the program stops after the physical scan. (can hear from the scanner movment.) Nothing...
Hi, I have the same problem. I am running on the same computer with the same software Nikon Scan without problems. Found out that the problem happens mostly when a crop is selected that just eliminates the scanning frame. Without crop mostly OK. However no reason why and no real solution
Apr 15, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
Can't scan with Canon MF printer with New 64 bit laptop
You might try "viewscan". there is a free trial, but the software is not free if you want to use it for long.
https://www.hamrick.com/vuescan/supported-scanners.html
Jun 05, 2017 | HP PSC 1410 All-In-One InkJet Printer
Cannot scan from Lexmark printer onto laptop
As a work around try installing Windows fax and scan and using that program to scan your items - I have multiple printers and it works great for me
Aug 10, 2017 | Lexmark X3470 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
160 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
