Question about Wagner Air Tools & Compressors
Wagner electric asincronous H 100L4 1982 motor MK-250. Compressor will start, get up to pressure okay, but once pressure drops it will stall on restart and trip out mains.
    Scholar:
  • 104 Answers
The overload trip is is not rated high enough for the load. When the compressor starts form zero pressure their is little load on the motor. It then pumps ok to the cutout pressure under gradually increasing load. When it tries to start on the intermediate pressure the load is too great as the motor drawers a higher current on start-up and has the additional load of the higher pressure. You have a 15 amp appliance running on a 10 amp circuit or similar depending on your countries supply voltage.
Posted on Sep 06, 2009
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
My Craftsman 15 Gal Air Compressor trips the electric breaker at start up no mater where I plug it in.
Just fixed my compressor. It would start ok when the tank was empty but trip the breaker if it tried to start with pressure. Searched and read about weak caps, or problem with check valve or pressure switch leaving pressure in the pump head, etc. Turned out that the black plastic box which holds the 2 start up caps and is attached to the end of the motor with 2 screws had cracked on the bottom. The black box had tilted out enough that the start up caps switch was not engaging. Pushed on the lower part of the box and it started perfectly. Fixed it for the cost of some 2 part epoxy. Maybe not your fail, but definitely worth checking out first.
Apr 12, 2012 | Craftsman 15 gal Air Compressor 3 hp UMC...
Compressor runs to 175psi but trips pressure relief when pressure drops tries to restart motor but motor wont turn blows breaker. changed whole pressure switch have same problem.
The problem is lilkely the check valve between the compressor and the tank -- it is alowing pressure to build from tank to compressor preventing the compressor from turning over. Clean, maybe replace, check valve...
Charlie
Jan 09, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
No pressure getting through to gauges
remove the intake filter and check to see if the compressor is sucking or blowing if it is blowing out air from the intake you have a bad valve
Apr 26, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Air Compressor stalls when it reaches @ 40psi. Have a
You need to find an amp probe from someone and use it to monitor the amps as the compressor is building up pressure. If the amps start increasing dramatically as it nears the stall point it would seem that you have a seizing problem or electrical motor problem. This answer only applies to the exact statement that you gave. ( Air Compressor stalls when it ). Mike micmor68@gmail.com
Oct 25, 2009 | Air Tools & Compressors
Motor startup trouble while pressure in tank
My first thought was that the check valve is allowing pressure back into the compressor and preventing the motor from turning. That's still my best guess right now.
I think the cold weather start symptom is what you would see with any engine/motor -- it requires more torque to get it going. In this scenario, if the check valve weren't leaking, it would start okay when cold.
May 06, 2009 | Clarke Power Products Inc AC2001 2HP 4...
Hitachi ec12 motor hums after drop in pressue
There should be a pressure switch adjustment under the cover of the switch remove the cover and reset.
Feb 03, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Electric motor stalls
A compressor can stall before completing a cycle if the motor is not receiving correct power, such as when there is an extension cord being used or outlet is overloaded with other appliances. Other problems that cause this condition are in-tank check valve is leaking pressure back to the pump and weak or failed capacitor. Some volt meters have setting for checking caps. Reject the capacitor if reading is 90% of rated value. Rare problems include worn bearing or bad contacts on pressure switch. enjoy
Nov 05, 2008 | Campbell Hausfeld 20 - Gallon Air...
Air Tools & Compressors Logo
133 people viewed this question
Top Wagner Air Tools & Compressors Experts
JOHN LAPIER
ray gallant
 Andy
Andy
Level 1 Expert
Are you a Wagner Air Tool and Compressor Expert? Answer questions, earn points and help others
