Hi, Have following error Built-in HDD Error - Computers & Internet
Your statement seems incomplete, please detail your problem.
anma64.
Posted on Sep 06, 2009
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Toshiba 451c Color Copier experiencing error F105
Hi how are you this is jack my personal Id (jack_pak@hotamil.com)
Dear follow the procedure .....
Other service call
[F105] HDD other error
(1) Check if the connectors of the HDD are disconnected.
(2) Check if the connector pins are disconnected or the wires of harnesses are open circuited.
(3) Perform the bad sector check (08-694). If the check result is OK, recover the data in the HDD. If
the check result is failed, replace the HDD.
(4) Replace the SYS board.
Thanks
Best Regards,
Jun 30, 2010 | Toshiba Office Equipment & Supplies
Acer Aspire 5330 Hdd error code 14402 How can
Please try use following codes..
01560000
PLFU2RR
U0N5U05
RSIYMDE
W7XXAA1
VJHICXN
DUOXXYM
D8WWW15
May 18, 2010 | Acer Aspire 7720-6569 Notebook
Hdd error
Dear i have send a link of your problem in camcorder for hdd error .
if to use this link instructions you are solve your problem.
Hard Disk Error / Hard Disc Error Warning, "recording failed".
These cameras often give Hard Disk Error / Hard Disc Error Warning.
We can recover the video data from hard drive - these cameras often use 1.8" ZIF Hitachi Hard Drive with following numbers (we also recover from all others!)
20GB HTC426020G5CE00 HTC426020G7CE00 HTC426020G7AT00 HTC424020F7AT00
30GB HTC426030G5CE00 HTC426030G7CE00 HTC426030G7AT00
40GB HTC424040F9AT00 HTC426040G8CE00 HTC426040G9AT00
60GB HTC426060G8CE00 HTC426060G9AT00
Feb 14, 2010 | JVC Everio GZ-MG130 Camcorder
Sony Camcorder HDD error
Hi There ...anyhow i have solved this problem
Regards,
Lionel
Nov 17, 2009 | Sony HDR-XR100 AVC Camcorder
Stop: d0000144 unknown hard error
This is the sign of your HDD failing, the SMART error is the harddrives built in diagnostic telling you it's on it's last legs.
The stop error is likely just caused by some of your cache file being located on a failing part of the drive.
If you still can back up your data quickly, if you can't and need data off the drive it may be time to send it to a pro. Either way the new error is just an escalation of the HDD failure and will likely only get worse.
Sorry it's not better news,
Chris
May 05, 2009 | Acer Aspire 3680 Laptop
HDD Error!
Take it to a camera store or to a Best Buy store and see if the hard drive has a problem with it such as a bent recording head.
Did the hard drive format completely?
Nov 26, 2008 | Video Cameras
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
