Question about Ovens
St George DEO 7 oven temperature not going past 170
Same problem as above my St Geroge oven wont go over 170 degrees. It did this when we first moved into the house in June but then one day it began to work normally with high temps now it is back to top of 170 again.
  • merrillie Dec 30, 2009
    Thanks Simon
    The only answer I have so far is to buy a whole new control panel which will cost about $940.
    Meanwhile the top oven works properly sometimes and sometimes not.
    Luckily the bottom oven works fine.
    Thanks Simon
    The only answer I found after contacting the company and their recommended repair places was to replace the control panel with a new model at a cost of $940.
    Meanwhile I am putting up with the top oven working sometimes and the bottom oven working fine.
Merrillie,
we have this problem too on the top oven. I used to work at StGeorge and I'm an engineer, so if I find a fix, I'll let you know.
Simon
Posted on Dec 29, 2009
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Hotplate won"t turn off st george cc-600 cooktop
I have a St George glass cooktop with temperature sensor light.It takes forever for the light to go out when I use the main element and that section often feels like it is still heatinglong after it has been turned off.Can there be power leakage through the switch for the main element
Aug 21, 2010 | Ovens
DEO-6 top oven doesn't heat when fan oven is used
check wiring to cavity air pressure switch terminals eg the two wires should be connected to common(c) and Normally open (NO)
May 16, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Oven only reaches temp of 220 degrees.
meter the electric-220 metering the positives...110 metering 1 positive & ground at a time...Ohm the element if shows open(10 dollar multimeter doesn't move) then is bad.Can be reached from the back just above where the power attaches,for safety disconect the power
Jul 22, 2008 | Maytag 30 in. Electric Single Wall Oven...
Stove won't go below 170
The lowest temperture that the oven will control is 170 degrees. You would have to place a suitable thermometer in the oven and manually control the temperature if you want a lower temperature.
May 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
4,221 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
