3 wire white rogers zone valve operated by 2 wire thermostat any one have a wiring diagram?
It is technically possible use a 2-wire thermostat with a 3-wire zone valve, but you need a single pole, double throw relay like a fan control relay with one normally open switch and one normally closed switch. 2-wire thermostats only have one switch that is normally open. 3-wire thermostats have two switches......one switch that is normally open, and one switch that is normally closed. The fan relay lets the 2-wire thermostat simulate a 3-wire thermostat. It's possible, but usually it's easier to just get a 3-wire thermosts.
Posted on Jan 18, 2010
  • carl tessmann Oct 17, 2012
    thank you Mel I am off to buy a relay and try it out, if it works I can stop banging my head against the wall
Here's a link to an article I wrote about how to control a 3-wire zone valve with a 2-wire thermostat. http://www.geekwisdom.com/dyn/node/234
Posted on Jan 21, 2010
  • 2 more comments
  • edwardsn87 Nov 15, 2010
    i bought a 24v relay but mine isn't the same layout as yours can you help me wire it to a 5 prong relay. it has 30 85 86 87 and 87a on it
    I cant see the wiring diagram it will not open when I click on it.
  • Steve Moitozo
    Steve Moitozo Oct 18, 2012
    Sorry Carl. I've corrected the images.
  • carl tessmann Oct 20, 2012
    Thank you got it now and I appreciate your time and effort to share your knowhow.
    Sergeant:
    Champion:
  • 232 Answers
  • 99 Answers
You need to use a three wire connection, two wire will not work.
http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0298.pdf
Posted on Oct 09, 2009
2 Suggested Answers
joselito_578
  • 22 Answers
SOURCE: connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. Make sure to connect a thermostat that will power open and powered closed the zone valve. I pretty sure that the two wire thermostat that your going to connect will not be compatible. To better assist you with this further contact us directly at 18002842925.
Posted on Oct 16, 2012
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
How do I connect a 24v damper motor with 6 colored wires red white yellow green blue black to NO COM NC terminals.
Choose two colors of the thermostat wire, and connect them to the NO and COM and connect them to the zone control board leads for the zone intended. Almost all zone valves spring return open when deenergized. So ensure the zone valve is open with the system is off. At the base of zone valve there is a set screw that needs to engage the damper valve shaft in the open position with the motor in the spring release position. Most zone valve are 90 degree moment from full open to full shut. If you have a Carrier zone valve, they go full open to full shut in 45 degrees of motion. Your open stop need to be set so the valve stops in the full stop position.
To help understand the operation of a zone system, say you have 2 zone system and zone 1 thermostat initiates a heat or cool demand. Zone 2 valves energizes and shuts and zone 1 stays open and allow air to heat/ cool zone 1. If zone 2 thermostat simultaniously initiates the same heat/cool demand, the zone 2 valve opens and both zone heat/cool. When either thermostat is satisfied the opposite zone valve closes and when both thermostat are satisfied both zone valves open.
Hope this helps you understand zone operation. The same works for higher multizone systems.
Jul 27, 2014 | Honeywell Motorized Small Rectangular Hvac...
Honeywell how to install
Did you try E too aux and x1 to c?
Jul 20, 2014 | Honeywell RTH6580WF Wi-Fi Thermostat
Honeywell thermostat
The wiring is correct but you have a programmable thermostat that needs to have a program to operate. The manual for this particular stat is straight forward and uncomplicated. Enter the times and functions with the right button and up/down arrows then press "DONE" (Left Button) to get it started. Hope this helped. Roger
Jan 30, 2014 | Heating & Cooling
Connecting 2 wire thermostats to white-rogers type 1311 3 wire zone valves
Oct 15, 2012 | Heating & Cooling
Replacing WHITE-RODGERS manual thermostat with 3 wires ( red, white, blue and installing Honeywell electronic thermostat RTH110B, how do I connect it? The heating is not central, baseboard heating.
I have only seen one Honeywell thermostat that would work with a 3-wire heating system.
I would replace it with a White-Rodgers 1F80-0471. They are about $100, but they are a good thermostat, and they work well with the 3-wire zone valves.
Most other thermostats have the "Y" terminal that you need, but do not control the zone valve correctly.
Helping Hands Services
- Fairbanks, Alaska -
Jan 30, 2010 | Honeywell Electronic Programmable...
I have a red and a white wire but the heater wont
It sounds like you have at least 2 zones in your system. If this is a normal hot water boiler system with zone valves. When you have your thermostat call for heat it closes the 24 volt circuit that then energizes the motorized zone valve for that thermostat. In that motorized zone valve there is an end switch that will close and complete the circuit to the boiler. Zone valves when they start to clog up with mineralization will not allow the motor to go far enough to close the end switch, so then the boiler and circulating pump will not come on. If this is the case then you need to have the zone valve replaced.
Also make sure your wires at the thermostat are connected correctly. One thing you could also check at the thermostat to make sure it works or not is to jumper the 2 wires and see if your system starts up or not. If the system starts up then the thermostat or its subbase is defective. Hope I was of help to you!! Good luck!!
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Newly installed white-rodgers zone valve works for a while then eventually moves to manual (or open) on its own. Suggestions on how to keep valve in a closed position? Chris in Alaska
This problem has to be in the way the valve was wired. Wrong zone valve-Normally open instead of normally closed-power interuption causing valve to open. Faulty T-stat/ Most likely wired incorrectly.
Sep 13, 2009 | Plumbing
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
2,482 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
