Question about Ahead Software Nero 7 for PC
I have Nero 7, when transcoding and burning a dvd the total progress is many hours more than the curent progress, it used to only vary by about 5-10 minutes tops, can you tell me how to fix this. I have uninstalled the Nero and all its info. and then re-installed a different version. I have taken the same movie to my grandsons computer and it transcoded and burned fine. The current progress was only a few minutes less than the total progress
  • 78 Answers
SOURCE: burning
Check for some AudioVideo codecs are missing in your computer.
Posted on Aug 31, 2007
raverbaby
  • 59 Answers
SOURCE: nero express
hiya there builder999, Nero is not the best program to use for burning downloaded movies try this program here's a direct download link DOWNLOAD HERE http://tinyurl.com/2pctld i use this myself and boy it's the business you can make your own menu and the program with automaticlly link all files together that if for let's say" you downloaded a VCD 2, 700mb files and you want to put both on to dvd this program will do it for you give it a wiz check it out! by the way heres a screen shoot on the program Enjoy!! DOWNLOAD HERE http://tinyurl.com/2pctld
Posted on Oct 06, 2007
Sheruraj
  • 72 Answers
SOURCE: uninstalled nero 7 to put nero 6 back on but it's not working!!
Did U Checked ur Windows - Is it Vista - ?
If not Something got wrong n Now u have to delete the folder of Ahead From C:
Now Reinstall Applpication u might find the reason and the Thing -
Posted on Jan 15, 2009
Strippy
  • 55 Answers
SOURCE: help !! no nero plugin ,can not burn dvd's
hmm, this might be a stupid sugestion, but, did you chose your DVD burner, or did you chose Write an image file?
in one step, it says you got to chose ur burner, or your image writer...
check that...
Posted on Jan 17, 2009
  • 94 Answers
SOURCE: I am having a problem with the nero OEM suite
Before uninstalling check on-line for updates for the version of Nero that you have.
Posted on Jul 10, 2009
How do you burn dvd's?
You need a software to burn DVD, Im using the software called NERO.
BUt there are alot of software available for free on the internet.
Cheers,
KA
Jul 08, 2010 | Dell Studio 1737 Laptop
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
Hi i am not able to burn DVD's. I have tried differnt burning software's. However it is burning the CD's. I tried uninstalling and reinstalling the entire thing still it is giving problem.
try the total video converter in coverting your video files and convert there your your file if it is a video and convert and burn there your file but stop the burn there in total video converter just burn your file in nero 8 coz its faster to burn
i hope this can help you
Mar 28, 2010 | Computers & Internet
I just purchased a new DVD rewriter with Nero 7 Essentials, from Smartstart. I am trying to write an image file (.iso) to Memorex DVD+R disks. With the progress bar at 1% and before anything gets...
Were you able to write a single music or another file using Nero? Were you able to burn the image using the Active ISO burner? Did you try a new fresh blank DVD or are using the same DVD again? Try to free some more space from your C drive and then check again.
Oct 23, 2009 | Office Equipment & Supplies
Nero Vision 4 refusing to burn to DVD (Memorex DVD Burner)
if its having problems writing the lead in, it,s possible that the devices drivers are corrupt or incorrectly installed. to resolve this re-install nero, or better still upgrade to a newer version of nero.
also check that your media/ blank dvds are compatable. some writers support DVD-R But not +R.
if none of the above works, go into the device manager, and uninstall the DVD drive, reboot the computer, and re-install it. Other related problems are usually atapi or couffin drivers.
Mike @ compurepair.
Jun 11, 2009 | Memorex (32023237) DVD±RW Burner
Burning
u can get total video converter software... then u can write ur movies........
web site: http://www.soft82.com/download/windows/total-video-converter/
thank u
May 12, 2009 | Computers & Internet
Burning a DVD picture slideshow
If you have Nero Express, try using that, as it should prepare the data for you. Also it maybe that you don't have the correct "codecs" installed. There are some Nero updates you can download from Sony:
http://sony.storagesupport.com/product/125#documents
Hope these solve your problem.
Regards,
Tim
Aug 29, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Memorex DVD+R DL 8.5 GO 8X compatibility
If all you are looking to do is write a DVD (ie, burn ordinary OS-managed files onto DVD, without transcoding, etc.), or write transcoded DVD-structured files, or an .iso image file, then don't even try to use Nero. Use ImgBurn, it is 500% better for those kinds of tasks, and it's freeware. I use it to burn DVDs but use Nero to transcode files and create the VIDEO_TS folder files. I then use ImgBurn to convert them to an .iso file, then burn it to DVD, also using ImgBurn. URL: http://www.imgburn.com/
Mar 30, 2008 | Ahead Software Ahead Nero 6.3 Suite 1...
Ahead Software Nero 7 for PC Logo
73 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
SHIVAJI YADAV
SHIVAJI YADAV
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
