Question about Microsoft Xbox 360 Console
E 74 SYSTEMS FAILURE E 74
    President:
  • 1,197 Answers
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
if changing the cable doesnt work..... i came across a link that i believe would be useful for you....
http://www.gamezine.co.uk/news/microsoft-extends-warranty-cover-e74-$1287835.htm
alternatively you can register a complaint with microsoft by following the procedures provided in the below link...
http://support.microsoft.com/kb/941377
regards iversh
a very helpful rating is appreciated for answering your query.....
Posted on Sep 06, 2009
74 bonniville only runs on left side,new boyer ignition, new coils 6 volt ,new wires new plugs...new gas and filter
Only one side of engine runs? Could be a head gasket problem on the right. It is a mechanical issue, not an electronic or electrical possibility as in newer cars. Do a compression test of the engine to see if the right side has compression failure from a bad head gasket.
A 1974 model would be a 12 volt system, not 6 volts. The last 6 volt systems were in the 1950's. If your coil is 12 volt and the left side runs and fires good, there is nothing wrong electrically. Check for spark on the right side, it should have spark on all cylinders if good spark on the left side. If no spark on the right side,. maybe a problem with the rotor or the distributor cap.
May 30, 2016 | Cars & Trucks
Winchester model 74 serial # 11901, what year was that gun made
My Internet at work doesn't like 'weapons'. These links will help you find the date.
Model 74 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
Winchester Model 74 .22 sr dating question ' The Firearms Forum
www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
Winchester Model 74 Value And Date ' Gun Values Board
www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
Jan 22, 2016 | Winchester Optics
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
What number color cartridge does C5280 use
Hi- HP 74 is black and HP 75 is color. Here is a link to hp's site for a combo cartridge HP 74/75 Ink
Thanks
Aug 30, 2010 | HP Computers & Internet
Keep getting this message incompatible ink cartridge on my hp photosmart c4480 all in one printer, helppppp
Hp knows about your issues you can read the forum here, Currently there working on a critical update.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-and/Incompatible-Cartridges-after-Critical-Update-HP-Photosmart/td-p/107505
Let me know ether way we are here to help. Please do not forget to leave a rating before you go, thanks
Aug 10, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Put new cartridge in officejet j6410 and overnight it now says cartridge on left needs replacing. put old cartridge back in and it still says the same thing
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", "cartridge in wrong slot", etc.) typically indicate the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
Dec 26, 2009 | HP Officejet J6410 All-in-one InkJet...
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
My HP Officejet J6480 all-in-one gives me Cartridge error: Cartridge on right must be replaced. I have changed the cartridge but still get the message.
These types of 'severe' cartridge errors/alert messages (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below:
Oct 03, 2009 | HP Office Equipment & Supplies
Cartridge error hp officejet j6480 generic cartridge
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
Sep 21, 2009 | HP Office Equipment & Supplies
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
